i9500 no mic/earpiece & ringer i9500 no mic /earpiece/ringer already change ringer/earpiece but same change u910/u902 but same also reball u300 can u300 also cause audio ( mic /earpiece / ringer ) problem all 3 stopped at the same time |
baseband ic also cause audio problem and not making call problem ? |
i9500 no mic/earpiece & ringer check this link please help full 4shared.com - free file sharing and storage - Login best regards faisal |
[B]the picture u given is i9505 not i9500 i need solution for i9500[B] |
any idea mates............ ? |
@ d-artigo will u please trace the links of audio lines and signal lines under baseband ic |
not a single member have idea about this ? |
I had already adwise you that remove U910 and check all point which comes from baseband ic U300 you had not reply. All member has their on level and not possible they had faced same problem. By posting same irritating post many you will get fast help. |
ok i think than for sure u300 cause this issue actually i have not same pcb of i9500 to trace tracks hopefully any of the member who have same pcb trace the links actually i dont have doubt on u910 bcoz initially i only work on u300 |
if c3-6 (vsd3_gnd) is missing then it cause this problem or not ? |
its c306 |
