05-03-2009, 14:53 | #2 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | try to heat slowly from the other side of the connector not on top of it.Within some time you can remove it. Be careful otherwise you ll melt the plastic of the sim holder. |
05-03-2009, 18:10 | #3 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Europe Wienna
Member: 984046 Status: Offline Thanks Meter: 255 | Well... I do it differently... 1. Wrap main PCB with some Aluminum foil - leave conn. uper side un-covered. 2. You can apply pretty much heat on uppper side as you want. (do NOT over step it - I dont mean that you can use welding torch!!!) From 1-9 heat scale - up to 4.5 is sufficient. 3. Heat until you can remove it with tweezers. 4. Clean pads on PCB with solder wick and wide solder tip. (all of them - that means conductive - on backside of conn., as and constructive - which is grounded and more of mechanical nature - hold's connector to a PCB) 5. If recall corectlly - you'll sometimes have trouble with front two trough-hole mechanical pin (after removing conn. - solder will cease and fill the hole in which you soppouse to insert pins from a new conn.) - I usually solving this by forcing sharp tipped scalpel trough it, and little by litle wide-ing it - if is too much solder in holes - just press scalpel and apply heat with solder (wide tip) from other side of PCB. 6. Put new conn in place - ensure that is correctly placed and solder it with regular solder (apply some flux on el. part of conn., it eases soldering process) Also think, that it can be removed with some regular solder iron (50w) applying solder on top of it, and heat until released. BR Haltec Last edited by Haltec; 05-03-2009 at 18:15. Reason: add info. |
The Following User Says Thank You to Haltec For This Useful Post: |
11-27-2010, 13:54 | #7 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 422574 Status: Offline Thanks Meter: 85 | salam/hi for the green card you can remove it by heating green card (e250 v 2006) While the Blue Card (e250_D-e250i-e251) If you want to heat it you should leave it cool down after (25 m) mr: riad |
What is the Best Way to Remove Charge Connector of Samsung Phones | powerplay83 | Samsung Hardware Repair | 6 | 07-14-2010 03:11 |
What is the correct way to connect the mobile phone in the box? | marcopolod | Z3X-Team Products | 1 | 01-26-2010 09:34 |
what is the correct way to write rpl how? | jackyivan | Universalbox | 4 | 05-08-2009 14:56 |
what is the correct way to write rpl how? | jackyivan | Universalbox | 0 | 05-07-2009 13:49 |
what is the correct way to unlock coral 100 | ruvanw1979 | Infinity-Box | 9 | 11-21-2008 13:55 |
