Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 08-01-2015, 06:41   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
s7262 no service problem
imei and basband is ok
when insert sim , the sim is detected but show circle in place of signal
when search manually it show there is error while searching network
already flash the phone,efs etc
Old 08-02-2015, 03:47   #2 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
any member successfully solved this problem ?
Old 08-02-2015, 04:21   #3 (permalink)
Member: 678375
Sonork: 100.1645205
Thanks Meter: 42
yes friend solved min 5 phones... just change clock crystal of network, and your problem solved.. try and reply
The Following User Says Thank You to purshottam For This Useful Post:
Old 08-02-2015, 04:27   #4 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
u have pcb diagram ?
Old 08-02-2015, 04:52   #5 (permalink)
linux_sh's Avatar
Member: 865141
Thanks Meter: 140
Heloo
Originally Posted by purshottam View Post
yes friend solved min 5 phones... Just change clock crystal of network, and your problem solved.. Try and reply
helloo r crystel 1 rx crystal 2 - tx crystal who chache crystal
Old 09-10-2015, 06:41   #6 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
i reball rf ic/change crystal/ change pa and filters after that signals ok but after 2,3 hours signals are unstable or no service after assembling the set
Old 09-15-2015, 16:37   #7 (permalink)
sachu2002's Avatar
Member: 2362867
Sonork: ththtuu
Thanks Meter: 659
remove network antina nd make jumper 10000% ok
Old 09-15-2015, 19:39   #8 (permalink)
Member: 2095374
Thanks Meter: 24
just replace crystal of network 10000% solve many time tested
Old 11-25-2015, 05:09   #9 (permalink)
Member: 1988630
Sonork: 100.1684003
Thanks Meter: 315
you are gread solutions 10000?% ok
Page generated in 0.16955 seconds with 8 queries
