P400 no back light on Lcd screen Does anyone have the solution |
Check driver for EL-Backlight. or change lcd. |
...or flex cable. Regards Shiljo |
I think most probably is the flex cable, but does anyone have the pic to show the pinout, i think the thread is o/c so need the pic to show me so i can use wire to solder the point |
@Shiljo.. When you change the lcd you also change the flex.... |
Yes,but...flex cable is <10EURO and complete LCD with flex cable is >40EURO and it is very hard to find it... Regards Shiljo |
1-you sure test and replace flat lcd or backlight 2- check the connector board 3-replace or change the (LTYN) IC 100% OK |
hi i have same problem no light lcd but i don't want to change flex i want just to know if someone can help me to put 1 wire ..light ways on flex cable....need a chip solution...not expences |
change the flex cable. this is the problem(in most of the cases) |
Usually changing the flex will fix the problem. |
change LTYN another change flex |
