Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 06-02-2004, 19:22   #1 (permalink)
Registered User
Steph's Avatar
Member: 17846
Thanks Meter: 4
Paused by temperature
What is this problem, it always come up when i plug the charger to the phone...
Old 06-02-2004, 20:16   #2 (permalink)
mailhassan's Avatar
Member: 23834
Thanks Meter: 27
hey,
that problem most common in v200. it makes it difficult to power on and power off most times. well rehot v100 i.c. and problem solved. if not then replace the i.c.
Old 06-03-2004, 09:38   #3 (permalink)
Registered User
Steph's Avatar
Member: 17846
Thanks Meter: 4
Thanks mate, it is true, its difficult to turn ON...
But can show me where it is located on the PCB?
The Following User Says Thank You to Steph For This Useful Post:
Old 06-03-2004, 10:44   #4 (permalink)
Member: 17193
Thanks Meter: 16
Not enough clear things here...
1.What handset?
2.If it's v200, here's the screenshot.
3.You probably thought of u100 (pw supply), v100 doesn't exist.
4.Check the pcb for water damage first.....
br
Old 06-03-2004, 20:14   #5 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
need to know abt C100's "Paused By Temperature"
Old 06-04-2004, 05:20   #6 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,419
@amir
for c100
chek LTRD if its ok , pz. flash the phone and rewrite iemi with the help of winiemi.
Old 06-04-2004, 11:55   #7 (permalink)
Member: 17193
Thanks Meter: 16
Hello mate.
In my case, reballing of flash IC solved the problem.
br
Old 06-05-2004, 16:54   #8 (permalink)
chip_2000's Avatar
Member: 22400
Thanks Meter: 44
i change U100
reflash phone
change imei
flash init
not result
______________________
any ideas ?
Old 06-05-2004, 17:24   #9 (permalink)
Member: 17193
Thanks Meter: 16
Try changing system connector.
Old 06-06-2004, 12:45   #10 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 81
a mor explanation please !!!!!
Old 06-07-2004, 11:11   #11 (permalink)
chip_2000's Avatar
Member: 22400
Thanks Meter: 44
system conector i check first - all ok
Old 08-29-2004, 10:14   #12 (permalink)
Member: 79655
Paused By Temperature - Samsun V200
I have a Samsung V200 phone which won't charge. I get the error above
I have read a few posts which say resolder U100 (or v100?) . I ave also found a schematic on one of the posts.
Before I do anything
Can someone provide me with a recommended list of actions to follow i.e. do I need to flash te phone again, etc
thanks
PS If I need to change this v100 chip, were can I et a replacement
Old 09-03-2004, 20:01   #13 (permalink)
::GSM-27::'s Avatar
Member: 19423
Sonork: 69566
Thanks Meter: 246
hi u just rehot U100 and i remov small bateri near ic
not ( v100) i resolved this problem last days worcking perfect for me !
Old 09-27-2004, 10:52   #14 (permalink)
TONYTONY's Avatar
Member: 35975
Thanks Meter: 19
D410 HAS THE SAME PROBLEM.
Tried to re-flow power IC but still same problem. Any other solution?
tonytony
Old 09-29-2004, 20:17   #15 (permalink)
Member: 79647
Maya Plz Define Here Which Part Near The Ic {or Remove Cell ?}plz Explain I Dont Undersatnd Yet {if Its Not A V100 Fault Than Which Part U Changed Plz Define Beacuse Lot Of Beignner Are Reading Ur Post And Ur Solution They Didn't Understand Like Me
c100 pause by temperature RAHUL12345 Samsung Hardware Repair 8 03-09-2006 12:03
V200 Pause By Temperature!! dexter2 Samsung Hardware Repair 16 11-06-2004 11:47
paused by temperature on v200 aldrex Samsung Hardware Repair 3 05-16-2004 12:49
My S300 Show Paused By Temperature When I Conect Charger Mahmudul Trident/AGERE Platform 5 09-23-2003 13:24
Q100 paused by temperature debeliamark Trident/AGERE Platform 3 07-19-2002 04:26
Page generated in 0.26016 seconds with 10 queries
