PLS HELP sgh D520 charge problem samsung d520 when i put the charger I hear a beep but the phone does not display the progress bar.i try to change the connector & charger IC but same problem.pls helps me |
1) check u battery is good ? if think try with other battery see 2) check battery connector if good solder 3) if solder then clean with alcool or others produits . 4) always same check charge connectivity line . try the 3 first solution before. |
all it's ok friend but can you post me the charge connectivity line pls |
schematic samsung : http://www.shrak-mobile.com/eng/sm_samsung.html |
thank you friend..i will try |
