Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 10-16-2009, 22:28   #1 (permalink)
Member: 422665
Thanks Meter: 2
PLS HELP sgh D520 charge problem
samsung d520 when i put the charger I hear a beep but the phone does not display the progress bar.i try to change the connector & charger IC but same problem.pls helps me
Old 10-17-2009, 01:21   #2 (permalink)
Member: 857234
Sonork: Dc
Thanks Meter: 196
1) check u battery is good ? if think try with other battery see
2) check battery connector if good solder
3) if solder then clean with alcool or others produits .
4) always same check charge connectivity line .
try the 3 first solution before.
The Following User Says Thank You to djibrilcoulibal For This Useful Post:
Old 10-18-2009, 01:45   #3 (permalink)
Member: 422665
Thanks Meter: 2
all it's ok friend but can you post me the charge connectivity line pls
Old 10-18-2009, 17:52   #4 (permalink)
Member: 857234
Sonork: Dc
Thanks Meter: 196
schematic samsung : http://www.shrak-mobile.com/eng/sm_samsung.html
Old 10-19-2009, 08:36   #5 (permalink)
Member: 422665
Thanks Meter: 2
thank you friend..i will try
D520 charging problem rirou Samsung Hardware Repair 1 04-20-2011 15:15
SGH P850 Charging Problem Help m Please morad80 Samsung Hardware Repair 2 11-28-2010 15:42
SGH D520 VIBRATION problem [email protected] Samsung Hardware Repair 0 02-20-2007 18:47
pls help sendo s200 charging problem macdan Various 0 03-25-2005 18:12
pls help with r310 charge problem .::AkhavanGSM::. Old Ericsson Phones & Sony Phones 0 10-24-2002 17:04
Page generated in 0.27446 seconds with 8 queries
