S300 no power with LCD hello i have one s300 seem dead but when you remove lcd the phone could power on i think is a short circuit i try with new ribbon ->same pb need a solution please help :eek: |
ok i will check the power ic |
any luck? I am facing the same prob....backlight of the lcd was off then tried some soldering of joints on the bottom of the lcd and then phone turned off permanently... probably i have s/c something instantly and now phone doesn't turn on... what do you suggest? checked fuse.. Service manual says that i should check the bridge on the lcd connector but dont which part is that.... |
I think LCD is just damajed or wet. Also check it for shorts |
i change with a new lcd same pb |
