Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 11-25-2009, 07:57   #1 (permalink)
Member: 53215
Thanks Meter: 17
s5600 charger problem. schema?
please charge schema and charger chip?
phone on .charger and power off phone. usb cable and power off pohone.
help. samsung s5600 charger ?
The Following User Says Thank You to edazor For This Useful Post:
Old 03-08-2010, 11:41   #2 (permalink)
Member: 1147157
Thanks Meter: 9
http://rapidshare.com/files/360565068/Troubleshooting.pdf
hello mate check this press thanks if helps
Regards,
GSM-UK
The Following User Says Thank You to GSM-UK For This Useful Post:
Old 04-09-2010, 23:34   #3 (permalink)
gsmspecialist2's Avatar
Member: 66001
Thanks Meter: 16
Can you post it again please, the link is broken.
Old 04-12-2010, 08:50   #4 (permalink)
Member: 53215
Thanks Meter: 17
link dead?
please schema?
Old 04-12-2010, 22:42   #5 (permalink)
chohansahib's Avatar
Member: 719944
Thanks Meter: 2,117
Originally Posted by edazor View Post
link dead?
please schema?
Hi dear,,
here is the solution for ur fone prob,,,,,,,try this and solve ur prob
The Following 19 Users Say Thank You to chohansahib For This Useful Post:
Old 05-20-2010, 13:50   #6 (permalink)
Member: 46247
Thanks Meter: 8
Originally Posted by chohansahib View Post
Hi dear,,
Thanks s5600 is charging!
Old 06-16-2010, 17:43   #7 (permalink)
i am the master's Avatar
Member: 996052
Thanks Meter: 35
Regards,
GSM-UK
this address is not working any more i have phone s5600 chargig port is ok and all track are fine can you guide me were is the charging ic plese
Old 06-16-2010, 17:45   #8 (permalink)
Member: 996052
Thanks Meter: 35
Hi dear,,
i need to know were is charging ic any help ..........?
Old 07-22-2010, 10:27   #9 (permalink)
Member: 79291
Thanks Meter: 9
hello
Hi dear,,
for me worked ok, thank you
Old 07-29-2010, 09:03   #10 (permalink)
Member: 557934
Thanks Meter: 11
Somethimes in some phones when i apply this jumpers the phone goes to usb mode.Even if i remove the connector and make only charger ways when connect the charger it going to usb mode.Does anybody know something about this problem?
Old 09-18-2010, 11:23   #11 (permalink)
Member: 893454
Sonork: aa
Thanks Meter: 9
Can u explain man what u did,, apply Jumpers marked in REd color or jumper between those 2 Pins ???
Old 10-19-2010, 12:34   #12 (permalink)
Member: 545376
Thanks Meter: 19
My solution is here:
Resolder or change this part when doesn't charge!
The Following 2 Users Say Thank You to 25011 For This Useful Post:
Old 11-05-2010, 16:18   #13 (permalink)
Member: 289307
Thanks Meter: 44
s5600 is charging now normely
Old 11-08-2010, 19:52   #14 (permalink)
Member: 49046
Thanks Meter: 25
Hi dear,,
sorry but i have the same problem !
When i plug charger or usb cable it power off and when i unplug it restart !!!
i don't understand because i changed the charge connector but it's same !
what is the problem please !
I tried all solutions in this forum but no SUCCESS !
Any help ?
Regards
The Following User Says Thank You to beling For This Useful Post:
Old 11-09-2010, 15:35   #15 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 781
The Following 2 Users Say Thank You to drjaved_akhter For This Useful Post:
S5600 Unlock Problem reserve UST Pro II 0 09-14-2009 12:58
s5600 unlock problem dika_gsm_dz UST Pro II 0 09-07-2009 12:33
s5600 unlock problem!!! m_choko UST Pro II 0 09-01-2009 14:07
S5600 unlock problem umadineshdas Z3X-Team Products 2 08-05-2009 04:53
S5600 unlock problem lucky_gsm UST Pro II 1 07-15-2009 21:21
Page generated in 0.24641 seconds with 10 queries
