06-01-2017, 11:26 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | SM-925F S6 Edge No Power Without Charger after i clean it, it power on but only if with charger. after disconnect charger, phone will not power on, i changed battery, repaired the battery terminal and check for lines with tester all is ok. any idea what could be the problem? |
06-05-2017, 22:51 | #3 (permalink) |
No Life Poster Join Date: Jan 2013 Location: lebanon
Member: 1869842 Status: Offline Sonork: 100.1625473 Thanks Meter: 186 | reballing pmic ic will solve your probleme many time solution of this probleme for many devices |
The Following User Says Thank You to habibboxes For This Useful Post: |
10-10-2017, 11:40 | #4 (permalink) |
Freak Poster Join Date: Jun 2003 Location: LZ - Bulgaria
Member: 30940 Status: Offline Thanks Meter: 13 | Make jumper from VBAT+ as on the picture - near battery connector. Be careful, because the space is very limited. |
The Following User Says Thank You to symbiah For This Useful Post: |
