02-19-2022, 10:40 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 41
Member: 79221 Status: Offline Thanks Meter: 8 | Samsung A40 Charge Problem I have same charge problem with lot of Samsung A40. First change flex charging cable and work for 1 week or more times. But the problem comes back. I change the part again but it's same... Don' t charge. The only solution is press the connector. I checked the connection which is clean Have you ever encoutered the same problem and what's the solution? Thank you in advance |
03-01-2022, 19:05 | #3 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 252 | no need to change anything if usb port is good or no water damage..i have 100% success in this problem in A series by jumpering usb vcc from charging board to the mainboard..and did not get any backjob in it |
