Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 10-15-2017, 14:09   #16 (permalink)
Member: 2768323
I'm sorry, I do not know English and I'm writing from a translator.
I have the same problem with the phoneme but I can not remove the speaker panel how to do it?
Thank you for your help.
Old 08-25-2019, 06:55   #17 (permalink)
Member: 2922856
Hi... i have a B2710 and no sound on the loudspeaker
some one has more pictures.. and how do that soldering?
i can not remove the black plastic that cover the battery, i only lift a little only to see that inside there is a old small battery with corrotion
and other question the Loudspeaker is bad ??
if I only remove the battery and remove the 4 o 2 pieces in the pictures i will get sound?
Old 09-09-2019, 15:18   #18 (permalink)
Member: 709218
Thanks Meter: 2
work 100/100 thank you
Old 06-14-2020, 21:29   #19 (permalink)
Member: 2959697
Blacki, excellent research and solution!! Thanks a lot! Needed both cables as shown in your picture to get the speaker back to work.
(The battery had green crust and some 'sweat' on the top contact. The upper left varistor (or whatever) as indicated in your picture was loose an its contacts black. Making a short cut just there was not sufficient. The upper wire alone as in your picture was also not sufficient. The lower left varistor (or whatever) was still in place. The lower wire from there to the right as the shown in your picture made the speaker loud again!) Needs some patience to solder in that tiny area...
Thanks again!
Old 10-28-2020, 23:26   #20 (permalink)
Member: 2971273
How to remove the plastic that holds the speaker?
Hello, thanks for these instructions! Unfortunately I have not managed to remove the black plastic that holds the speaker and hide the interesting part of the PCB for this repair.
Can you give me some advice? It seems very hard to remove it without breaking the whole thing.
Thanks in advance!
Page generated in 0.14322 seconds with 10 queries
