01-22-2014, 21:48 | #1 (permalink) |
Freak Poster Join Date: Jan 2011
Member: 1501506 Status: Offline Thanks Meter: 47 | I9300 Stuck in UART Mode After eMMC Repair Does anyone have a solution for I9300 which is stuck in UART mode after eMMC repair? I have around 3 pieces like this after eMMC is replaced. Device freezes and locks up while in PDA setting and reboots. After it is in UART mode only (*#7284#). Thanks! |
The Following User Says Thank You to connexion2005 For This Useful Post: |
02-02-2014, 06:31 | #4 (permalink) |
Member: 1501506 Status: Offline Thanks Meter: 47 | Thanks for the reply. U506 does indeed become unsoldered and need replacement but in this case, it is not my problem. It must be some other voltage overload component that is damaged from heating causing this issue as the phone tries to boot with standard PDA mode enabled in *#7284# settings, then freezes and crashes and reboots with UART mode enabled instead which is also very unstable. |
02-02-2014, 08:02 | #5 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
02-02-2014, 08:16 | #6 (permalink) |
Member: 1501506 Status: Offline Thanks Meter: 47 | It seems the issue I'm having is related to CP not getting sufficient power from some source. It is causing it to lag the system and crash it and switches from PDA to UART. Also locks up when the screen is off for an extended period of time. |
