03-31-2017, 20:22 | #5 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | @gsm-raj , by removing or bypass ic , mobile not work for everything . you need to replace it with new or working one for perfect work . and that's not a power ic . that's a usb charge pump up (charging ic) ic . |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
04-07-2017, 19:14 | #7 (permalink) |
Freak Poster Join Date: Sep 2007 Age: 36
Member: 579725 Status: Offline Sonork: 100.1675677 Thanks Meter: 96 | IC name is SM-5703a .. wich have charging ,, he alrady mention the ic position , an other use full thing wich i can shere with friends , that some time we got J700h short like wich is taking 13 14 pulsss on power supply , that problem i solved many times in this ic SM-5703a . |
10-21-2017, 08:56 | #8 (permalink) |
Major Poster Join Date: Oct 2013
Member: 2038521 Status: Offline Thanks Meter: 3 | Samsung j700f fake charging done by using diot ... i also do not recommend for this direct volt passing solution . but i just show you when you can not fix and think ic changing too much risky for you so you can try this method .. |
The Following User Says Thank You to Shopneelakas For This Useful Post: |
