Samsung E900 Dismantle Hi..I want to replace the ribbon on the E900 but not sure how to dismantle the phone. i get as far as removing the 4 screws on the back but can not get the back off. Does anyone have any dismantle instructions they can share please? Thanks |
im not sure but id say it cant be that far different from the d500 and d600 so take a look at the d500 dismantle video might help ya |
Same here, not the same as D500 or D600 |
Once you get the back off it's pretty much the same as D500/D600 but the problem is getting the back off. I've taken off the 4 screws but there are 2 "hidden" screws I can't find. |
I think I've just susssed it. At the bottom of the keypad there are 2 square covers bottom right and left. lift them up and there are screws hidden under there |
Plus when you've taken these screws out don't try to pull the shell apart as there is a wire connector to flick out first. Once the bottom and sides are split push the back cover upwards to finally seperate the shell |
No problem, glad to help |
Sorry for being stupid but I just couldn't find the two hidden screws from Ddavez's tip which was " At the bottom of the keypad there are 2 square covers bottom right and left. lift them up and there are screws hidden under there ". I searched underneath the keypad and etc but I still couldn't find the two hidden screws. I was wondering if anyone can lead me to find the two hidden screws? I need to replace my busted LCD on the E900. Thanks! kingster147 |
samsung e900 dissasembly excellent page check it out good luck http://www.excelldirect.com/images/s...y/myalbum.html;) |
e900 I'ts the solder on the ribbon you will have the problem with desolder very careful |
