Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 04-26-2015, 15:28   #1 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
Samsung Galaxy S5 SM-G900H No service and No Sim FIX
Hi friend i am going to share my last weak experience with S5 G900H may be this will help other people also including me.
No Sim
1 = Received phone with No Sim fault.
2 = Sim VCC 2.8v was not working.
3 = Sim VCC come from NFC IC ( I not found this ic in market or any other mobile phone boards that i have.
4 = removed ic and found 2.8 volts from other place.
5 = i made jumper like picture below and sim working perfectly.
No Service or low network
1 = No network CPL100 was missed in board so i placed from other board.
2 = Now poor network removed F101 and got F101 VCC line was damaged by water.
3 = so repaired broken vcc line.
Something wrong in picture link link is blocked by admin so attached
Battery Drain
i have noticed that this phone Drain battery fast may be because i got 2.8 volt from other location. or little more shortage in phone because that was water damaged phone. please correct me if i do anything wrong. and if you are from Pakistan and can provide me NFC ic please pm me.
Press Thanks if you like
Regards!
ABDUL HAKEEM
The Following 11 Users Say Thank You to >>PakFones<< For This Useful Post:
Old 01-17-2016, 16:43   #2 (permalink)
Member: 2517251
Thanks Meter: 12
Good day! What if there is a continuity in Red, but the same problem exist? I could be one of the other pins of the SIM Card have problems?
The Following User Says Thank You to ScyberMhaster For This Useful Post:
Old 01-18-2016, 14:20   #3 (permalink)
Member: 2517251
Thanks Meter: 12
Is there a SIM Card IC or I should re-hot the NFC IC instead?
Old 08-25-2016, 02:39   #4 (permalink)
Member: 753102
hello i have the same problem on s5 G900F, can anyone help me please, thank you, signal poor and then lost, i have replaced the antenna flex, charging port flex, still the same
The Following User Says Thank You to heara For This Useful Post:
Old 04-27-2018, 10:26   #5 (permalink)
JONONItelecom™'s Avatar
Member: 1076772
Sonork: 100.1601881
Thanks Meter: 2,847
Fw.Ver : BstKey V3.41
Serial : A0E2-7D88-177E-AB4A
Active User: mehedihassan
PL2303 : 3.4.48.272 2013-02-05 (OK)
Best Smart Tools, Load OK.
Scanning devices ... 1 found
dev[1]
Manufactory:
Model:
Hardware:
Mode: unauthorized
Detect 2 USB devices not install driver
dev[1]
Manufactory: SAMSUNG
Model: SM-G900S
Hardware: QCOM
Mode: normal
Download: Press Vol Dn + Home + Power
UART Cable Resistor: 523 K
ReadCodes/Unlock/Repair:
1. Type *#0808# and set USB to AP.
2. Set "USB Settings" to "DM+MODEM+ADB".
3. Click "OK".
Cables: MicroUSB
Interface: Auto, Change UART when request
Read Info/Flashing/UserLock/Backup:
Cables: MicroUSB
Interface: Auto
Checking environment ...
System Info
Display ID: KOT49H
System Ver: 4.4.2 REL
API Level: 19
Incremental: G900SKSU1ANI1
Model: SM-G900S
Brand: samsung
Device: klteskt
Platform: msm8974
Language: en
Rigion: US
Device Info
SerialNumber: 96774b23
Hardware: qcom
Model: klteskt
PDA Version: G900SKSU1ANI1
Phone Version: G900SKSU1ANH2
Bootloader ver: G900SKSU1ANI1
Ril HW ID:G900S.08
Sales Code: SKC
Model ID:
Get Bluetooth info failed
Get WI-FI info failed
Network [1]: GSM IMEI: 352170061018284
Root Access: No root
Time used : 6.6 s
This operation need QCDI interface, setting phone as "Help" tips and connect phone with USB cable.
dev[1]
Model: SM-G900S
Hardware: QCOM
Mode: normal
System Info
Display ID: KOT49H
API Level: 19
Model: SM-G900S
Brand: samsung
Device: klteskt
Platform: msm8974
Language: en
Rigion: US
Device Info
Hardware: qcom
Model: klteskt
Ril HW ID:G900S.08
Sales Code: SKC
Model ID:
Time used : 6.4 s
Repair network ... done
dev[1]
Model: SM-G900S
Hardware: QCOM
Mode: normal
System Info
Display ID: KOT49H
API Level: 19
Model: SM-G900S
Brand: samsung
Device: klteskt
Platform: msm8974
Language: en
Rigion: US
Device Info
Hardware: qcom
Model: klteskt
Ril HW ID:G900S.08
Sales Code: SKC
Model ID:
Time used : 6.2 s
Connect to device ...
Device Authentication ...
Writing IMEI ...
Writing IMEI certificate ...ok, You need reboot device
Old 06-01-2020, 17:32   #6 (permalink)
CoMoBat's Avatar
Member: 1171122
Sonork: 100.1623220
Thanks Meter: 150
No Sim
Battery Drain
Regards!
ABDUL HAKEEM
I have No Service or low network problem and not solved by this solution
Page generated in 0.18941 seconds with 9 queries
