View Poll Results: Solution | |||
What is the solution? | 48 | 64.86% | |
Is this a hardware or a software issue? | 34 | 45.95% | |
Multiple Choice Poll. Voters: 74. You may not vote on this poll |
05-23-2018, 01:01 | #16 (permalink) |
Insane Poster Join Date: Dec 2014
Member: 2314949 Status: Offline Thanks Meter: 18 | Okey exactly in this order: 1-flash combo file and then dial *#33725327# 1.1-make backup efs 1.2-select menu 3 EFS CLEAR & RESTORE Phone will get signal in combination when reboots but next step is to flash stock and phone will be back to mipi fail, be patience, go thru all steps. 2-flash stock 2.1-root with engroot and .bat superSU 2017 on android 7 2.2- adb shell su am broadcast -a android.provider.Telephony.SECRET_CODE -d android_secret_code://27663368378 2.3- hidden menu shows 2 ue setting info 1 setting 2 system 3 nv rebuild 3 all Phone will get signal when reboots on stock firmware. Many users have done it as I wrote it. Report back please. |
The Following 3 Users Say Thank You to jkar5600 For This Useful Post: |
07-09-2018, 07:18 | #17 (permalink) | |
No Life Poster Join Date: May 2016 Location: 574 Age: 31
Member: 2567774 Status: Offline Thanks Meter: 255 | Quote:
It works. Follow the guide and back to MIPI TEST SUCCESS Previously, i was stuck on the screen No service NETWORK : UNBLOCK IMEI Certi: PASS,1 Unknown MIPI DEVICE FAIL DEVICE MID=0x217, PID=0x021 | |
10-10-2018, 13:19 | #20 (permalink) | |
Freak Poster Join Date: Mar 2018 Location: Karachi Pakistan Age: 30
Member: 2824001 Status: Offline Thanks Meter: 110 | Quote:
Hey buddy! its working for me on SM-G935A bin-4 Android7.0 | |
02-02-2019, 17:41 | #22 (permalink) |
Junior Member Join Date: Apr 2017
Member: 2702137 Status: Offline Thanks Meter: 6 | No need to change anything on sprint. Just downgrade to 6.0.1 then go to settings the last menu at the bottom then press vol + then vol - vol - you will get into service mode. Then go to network control and select all the bands of gsm and lte. Restart the device. You will have network |
06-27-2019, 16:24 | #24 (permalink) |
Moderator Join Date: Oct 2011 Location: U.A.E
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,712 | Hello Everyone, Today i got a phone G935A. That Phone Problem was Need to Change LCD. When our Technician change LCD after that we saw Phone need also Network unLock! I did unlock phone by octopus read code. Enter code after Phone showing Emergency Calls only! i Go Octopus Support section and i downloaded STOCK_MODEM_G935AUCS4BRC1.tar.rar File and flash it with Octopus tool. Magic! Phone Showing Operator Name! Before i write Stock Modem File i also replace That broken lcd but problem still persist. I dont know Every Phone had same Problem or not. But I Fixed it by Software.
__________________ __________________ Rules are for the obedience of fools and the guidance of wise men. Best Regards, Shamim |
06-27-2019, 18:07 | #25 (permalink) |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | MIPI Fail can be caused by two issues. 1. Hardware, either bad charging port board/flex, or mismatched meaning you can't mix up the G93xU (QC) with the G93x (Exynos) boards. 2. Software may work by rebuilding the EFS by the various method which have already been posted. I always try the hardware method first, because if it is in fact a hardware issue, then the software fix will not work anyway. |
07-01-2019, 03:02 | #26 (permalink) |
Junior Member Join Date: Jun 2017 Location: Argentina Rio Negro Bariloche
Member: 2725539 Status: Offline Thanks Meter: 0 | Hi, I try with mipi tool, combination, signal got back, but get lost in few minutes, changing the flex solved permanently, and u can flash last full firmware |
10-13-2019, 00:05 | #27 (permalink) |
Crazy Poster Join Date: Nov 2015 Location: Dar es salaam, Tanzania
Member: 2491870 Status: Offline Sonork: mussaj Thanks Meter: 11 | follow this method its working file Fix MIPI DEVICE FAIL for G935A - G935T - G935V - G935P REV8 | Yemen-Pro |
