Samsung i9000 galaxy s Hard reset Successfully following ARE THE STEPS 1. REMOVE BATTERY & PUT IT BACK 2. HOLD VOLUME UP BUTTON & MIDDLE BUTTON (HOME BUTTON) 3 WHILE HOLDING THIS TWO BUTTON PRESS POWER BUTTON AND REALEASE(PRESS POWER BUTTON ONLY ONCE) 4.IT WILL POP UP WITH HARD RESET MENU 5. SCROLL DOWN TO FACTORY RESET WITH VOLUME DOWN BUTTON THEN PRESS CENTER BUTTON OR HOME BUTTON 6. THEN PRESS VOLUME DOWN BUTTON TO SELECT YES FACTORY SETTINGS THEN PRESS CENTER BUTTON 7. SELECT REBOOT DEVICE AND PRESS CENTER BUTTON TESTED 1000% WORKING |
That doesn't work. Maybe the old ones... |
itts same model not works i tray many times same model i think not same version |
http://forum.gsmhosting.com/vbb/f352...-mode-1102588/ T939-I7500 Recovery Mode Vol down+Call+Power button to enter into recover mode ---Menu |
hello guys try this Volume UP + Home + Power and you should get the options menu reset. tested in a new samsung galaxy |
It doesn't work . Is there another way ? Thanks ! |
tried and tested... working perfectly! |
if you follow the step properly it will work i tried on 2 phone samsung galaxy s i9000 |
this procedure only works with the old version...new one does not work. samsung changed bootloader already |
10000%% working thanks br:) |
thanx tatan 1 its work with me thanx again................. |
Samsung i9000 Hard reset plase image step by step help me |
this procedure only works with the older i9000. the new ones have new bootloader and will NOT work. you need jtag the phone with a box like riff box. |
