Samsung i9300 safemode problem |
The phone goes into safe mode if u press the "menù" sub key during power... Restart the phone, and everything will work correctly... If the phone turns on in safe mode again, it probably has a problem on the menu button... menù button is the left-bottom key... |
check the volume down button. |
the phone put itself in safe mode to protect itself, it does that when an app is malfunctioning so check any new apps that you may add to the phone. |
Already flash with 4.1.3 and efs repair also done same problem |
Use *#0*# code to test the sub-key |
http://forum.gsmhosting.com/vbb/f258...emove-1736167/ |
