Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 06-14-2015, 15:32   #1 (permalink)
Member: 1759693
Thanks Meter: 54
Samsung s5830 not flash with odin. Need help?
Dear members I am tired of not flashing s5830. Cause it stuck on "setup connection". Anyone in the forum pls help me.
Old 06-14-2015, 15:37   #2 (permalink)
Hifzul Amin's Avatar
Member: 2144988
Sonork: 100.1655364(Offline)
Thanks Meter: 217
Smile Hello
Put Your File In Pda Tab of Odin
And Flash Your Phone
WBR
Hifzul Amin
If Problem Solved Press Thnx Only
Old 06-15-2015, 03:47   #3 (permalink)
Member: 1759693
Thanks Meter: 54
Still same problem. Not working for me.
Old 06-15-2015, 04:00   #4 (permalink)
Member: 2402217
select Pda tab
select Pda tab pda file
flash Odin_Multi_Downloader_v4.38
Old 06-15-2015, 06:20   #5 (permalink)
Member: 2405449
Sonork: 100.1660627
Thanks Meter: 2
Thumbs up hi
hello brother plz flash with z3x box old version if the again same then charging base check
Old 06-15-2015, 06:39   #6 (permalink)
lucky2010's Avatar
Member: 1322713
Sonork: 100.1663786
Thanks Meter: 254
Download This Multi Firmware
and Flash With 4 Files and also Put Pit File Try and Plz Post result
S5830XEKPP By KHALID
Cooper_v1.0 - Download - 4shared - Dinesh kumar
S5570_S5670_S5830_Odin Multi Downloader v4.38 - Download - 4shared..
if ur Prob Not Solve Contact me on Skype..
The Following 2 Users Say Thank You to lucky2010 For This Useful Post:
Old 06-15-2015, 11:49   #7 (permalink)
Member: 1759693
Thanks Meter: 54
S5830 restart after plugging in and out charger. Do u have any idea to solve it.
Old 06-15-2015, 11:54   #8 (permalink)
Member: 41105
Thanks Meter: 43
change the carging connector from pcb.
that is tipical problem at Samsung, not cleaning... change it
The Following User Says Thank You to kuli For This Useful Post:
Old 06-16-2015, 03:21   #9 (permalink)
Member: 1759693
Thanks Meter: 54
I already changed the charging connector. Still restart on charger plugged in and out. Any other way. Pls
Old 06-16-2015, 06:47   #10 (permalink)
Member: 41105
Thanks Meter: 43
take one multimeter and check the + line from charging connector or mesure ohm between + and -. i think you have some short circuit.
the phone was water damaged?
Old 11-25-2015, 05:51   #11 (permalink)
yasir kamal's Avatar
Member: 2148232
Sonork: 100.1658506
Thanks Meter: 31
100% working bro my phone is ook now
Old 11-25-2015, 10:01   #12 (permalink)
Member: 2477123
Samsung s5830not flash.
Check your battery bsi ways....
Old 05-04-2016, 19:34   #13 (permalink)
Member: 2345417
Thanks Meter: 9
yeh i tryed this file but not working i wating 25minutes any solution
Old 05-05-2016, 11:20   #14 (permalink)
Member: 2345417
Thanks Meter: 9
workiiiiinng thanksss
Page generated in 0.27891 seconds with 9 queries
