samsung n7000 full short samsung note1 n7000 full short solution need???????????? pls help me sir thanks in advance |
note1 n7000 in full shorting any solutions u have plzzzzz help me:(:(:(:(:(:(:(:( |
VBAT LINE GROUNDED. set the voltage on 0.5 v first. then connect power supply and slowly increase the voltage until power supply auto off ( ex: if power supply off when 1.7v then set the voltage to 1.6) sure there is a capacitor or IC will get heat but take some times. if it is a capacitor just remove it . if it is a IC you need to check the schematics which function of that ic before before it . good luck |
worked for me, thank |
But like galaxy s2, after removing this, the phone will not charge, im looking around to make a jumper otherwise i just replace the missing piece |
If i try to replace the missing capacitor the phone full short again, so the problem isn't the capacitor at all but the ic charge, now phone charging alternativetly like plug n unplug the usb cable all the time, the battery will charge but the screen will stay perma on ... any suggestion ? what can i do ? |
