03-10-2014, 21:59 | #1 (permalink) |
Freak Poster Join Date: Jan 2013 Location: Switzerland Age: 48
Member: 1873863 Status: Offline Thanks Meter: 67 | i9505 : Need a capacitor check i am searching a short somewhere into a i9505 board. The phone is working at 99%, everything apart wifi , but it heats very much (cpu and emmc). It was dropped from the 4th floor of a building, and i have already removed 2 shorted caps, but i suspect a short inside cpu. I need someone with a good Samsung S4 (i9505) board that can check for me the ohm value to ground of C854 (you can see it's position in the picture attached). C854 versus ground. Mine board show 8.8ohm , but this is a cpu power line of 1.05 so maybe is correct... but i must compare and i don't have other boards. Thanks ! Dave |
04-02-2014, 10:33 | #2 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Italy Age: 42
Member: 164613 Status: Offline Thanks Meter: 11 | Hi if you still need it, direct resistance (black to ground and red to capacitor) is 170 Ohm +-5 and inverted resistance is 280 Ohm |
The Following User Says Thank You to roso For This Useful Post: |
04-02-2014, 10:37 | #3 (permalink) |
Member: 1873863 Status: Offline Thanks Meter: 67 | Thank you roso ! Meanwhile, as i never received answer, i have bought a working S4 myself, to repair the other one... So, my partial faulty board must have some other shorts, even if the phone is working.. (oh, ho visto ora che sei italiano, grazie mille per l'aiuto !) |
04-02-2014, 22:14 | #4 (permalink) |
Member: 1873863 Status: Offline Thanks Meter: 67 | Ehy roso !! Good News !! Thank you to your measurement, now i finally found the shorted cap !! I have removed this cap and now i have 170ohm on this line !!! PERFECT, FANTASTIC !! Thank you very very much !!! |
The Following User Says Thank You to laptopmd For This Useful Post: |
