Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 03-28-2011, 12:06   #1 (permalink)
Member: 340774
Thanks Meter: 164
sasmsung galaxy i9000 charging prob
i ve sasmsung galaxy i9000.. and its problem is when i put it in charging it heats up.... there is no shorting but it get heated in just five mints... ant budy schmentic or any budy ve its soloution..... or charging ways
plz give soloution with pic or with schmentic
dont post fake soloutions
Old 04-04-2011, 15:04   #2 (permalink)
Speed_Demon's Avatar
Member: 249757
Sonork: 100.1601084
Thanks Meter: 117
have u tried another charger or battery ?
Old 04-18-2011, 01:14   #3 (permalink)
i am the master's Avatar
Member: 996052
Thanks Meter: 35
its common fault on samsung i 5700
just change sim gate your phone will be good to go
Old 01-15-2012, 16:35   #4 (permalink)
LordMen007's Avatar
Member: 184793
Sonork: 100.1574609
Thanks Meter: 45
Here's some hints on how to fix the Samsung I9000 Galaxy S Not Charging Problem:
1. Ensure that the battery charger you are using is properly working or try to use another one.
2. Visually check the USB pin connector for possible damaged. Clean it if oxidized, re-solder, or replace it if necessary. You can read the VBUS charge voltage at the pin #1 if the USB connector is okay.
3. Check or read the VBUS Charge IN voltage this is the output from the VBUS charger control IC.
4. Re-heat, rework the VBUS IC if the 5V is missing. Replace if necessary.
5. The power management IC will be the next option to re-work at if the procedures above doesn't solved the problem.
Old 01-15-2012, 16:41   #5 (permalink)
LordMen007's Avatar
Member: 184793
Sonork: 100.1574609
Thanks Meter: 45
Samsung Galaxy S I9000 Not Charging Problem Solution
The picture below shows some components of the Samsung I9000 Galaxy S, it points a test spots where to start a check up or troubleshooting procedures. It also show us which and what components needs to check first.
File Type: jpg SAmsung i9000 Galaxy S Not Charging Solution.jpg (43.3 KB, 2650 views)
Old 03-06-2012, 19:36   #6 (permalink)
faycal_gsm's Avatar
Member: 698787
Thanks Meter: 1,377
http://forum.gsmhosting.com/vbb/8209678-post2.html
The Following User Says Thank You to faycal_gsm For This Useful Post:
Old 04-12-2012, 12:17   #7 (permalink)
Member: 82476
Thanks Meter: 4
I have the same problem, but i've also notice that the small baterry near the 3.5 jack connector is the one that gets heated. any ideas?
Old 04-20-2012, 14:28   #8 (permalink)
Member: 82476
Thanks Meter: 4
my problem was from the charging connector witch was touching the buzzer flex. The red marked part is where the problem was.
Old 07-02-2012, 23:42   #9 (permalink)
Member: 948031
Thanks Meter: 3
Arrow nice' one :) :) :) :)
Originally Posted by faycal_gsm View Post
Wow nice post man' have a good work keep it up man.. thanks u for this
Old 02-11-2013, 15:03   #10 (permalink)
yassinek85's Avatar
Member: 938547
Sonork: 100.1591926
Thanks Meter: 481
Old 12-13-2013, 12:12   #11 (permalink)
Member: 2083882
Hi all,
I'm going to repair my I9000 usb connection but I would like to know before if I could try to power on the main board without battery, screen, etc. to test if 5v is ok on pin 1 of the USB connector.
Will I damage the main board if powered without the other component ?
thanks a lot.
Old 12-14-2013, 16:28   #12 (permalink)
Member: 2083882
Hi,
I did the procedure described in I9000 service manual p.36. using the mainboard only.
IFC300 (usb connector) pin #1 is 5V : OK
U503 DCIN (on C502 capacitor) is 4V instead of 5V ... is it ok ? Could it be U301 beeing dammaged ?
Thanks a lot for your feedback...
Regards,
Old 12-14-2013, 17:05   #13 (permalink)
Member: 2083882
by the way, here is a description of why I am trying to repair my I9000. When phone is off and I connect it to USB charger, there is an empty battery symbol and that's all. there is no battery filling animation on the screen as it should be.
Old 12-14-2013, 18:09   #14 (permalink)
yassinek85's Avatar
Member: 938547
Sonork: 100.1591926
Thanks Meter: 481
1-check the battery or try other have
2-check batery connector in board if its ok
Old 12-15-2013, 17:07   #15 (permalink)
Member: 2083882
hi, thanks for your answer.
battery should be ok because I tested with another one.
current battery is 3.9V and is ok to boot the phone.
battery connector is ok, tested with ohmmeter.
when powerwing only the mainboard with usb 5V, I measure around 3V on battery connector beetween middle pin and (left or right pin). there is 0v beetween left and right pin. Do you have information concerning battery connector pin ?
What about 4V instead of 5V on output from VBUS charger control IC (VBUS Charge IN voltage) ?
thanks for your help
Phone Not Charging tiggerwilk Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-21-2012 16:23
Charging. PhoeniX Nokia Hardware & Hardware Repair 7 07-06-2004 08:35
51xx charging problem kage Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 9 03-06-2002 00:42
how to charge your battery? g2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 12 09-26-2000 14:32
7110 contrast setting prob... RiddleR Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-04-2000 02:53
Page generated in 0.29862 seconds with 11 queries
