06-21-2006, 22:17 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Age: 56
Member: 11288 Status: Offline Thanks Meter: 23 | need help e630 problem can someone help me thanks to all |
06-22-2006, 00:00 | #2 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Be Age: 48
Member: 3081 Status: Offline Thanks Meter: 8 | Have you remove all varistors? They are on both sides of the board. Check this thread http://forum.gsmhosting.com/vbb/show...ht=e630+keypad Also clean very well the charging conector |
06-22-2006, 11:18 | #3 (permalink) |
Member: 11288 Status: Offline Thanks Meter: 23 | to MR FLUDOR thanks for replay men but i do all those things varistors +mic+volume keys+charge connecteur but stil the same if there is a new sugestion i wil be hapy thanks again |
06-22-2006, 11:20 | #4 (permalink) |
Member: 11288 Status: Offline Thanks Meter: 23 | to Mr fludor thanks for replay but i try all things varistors+mic+volume keys +connecteur but stil the same only power key work if ther is any sugestion i will be very happy thanks again |
06-23-2006, 01:15 | #5 (permalink) |
Member: 3081 Status: Offline Thanks Meter: 8 | U have to be very careful with those varistors, is posible that u mised one.Don't clean the volule keys just complete remove them the same with the micro. Try also a full flash but not the ones u find on twister suport, but a full flash copied with optiflash, tough i don't think is a software problem. No key pad has to be shorted to ground, if one of them is shorted then u've mised a varistor 100%.Take a service manual and check the keypad diagram see there how many varistors should be removed. I had few phones like this but i fixed them all by removing varistors or mic replace.Now i have no time to check but as i remember some of the samsung models have some diodes by the volume keys, also grounded, check if this one has and remove those also or replace. Good luck |
need help 5700 problem!! | ..::M-GSM::.. | Nokia Hardware & Hardware Repair | 3 | 09-14-2008 12:32 |
need help update problem! | sas-pc | Smart-Clip | 3 | 08-08-2008 08:10 |
Need help strange problem with Pc | c_ahmad79 | Off Topic Zone | 2 | 04-30-2008 18:52 |
RH-86 Nokia 1600b Need Help Unlock Problem | frankrizzo | MT-BOX | 4 | 01-06-2008 15:50 |
urgent need help twister problem | moncef | Twisterflasher | 2 | 02-01-2005 11:13 |
