02-27-2009, 19:44 | #1 (permalink) |
Junior Member Join Date: Feb 2009
Member: 982329 Status: Offline Thanks Meter: 0 | Samsung U600 Weird Touchpad Problem All the other parts of the phone work fine e.g. LCD, bottom keypad, side buttons etc. It's just the touchpad, when touched it doesn't do anything, so I can't get into the menu, answer calls etc. Any help guys? Thanks. |
03-28-2009, 16:51 | #9 (permalink) |
No Life Poster Join Date: Sep 2005 Location: The Netherlands Antilles Age: 50
Member: 179391 Status: Offline Thanks Meter: 57 | I have semilar problem, I did replace flex tape, touch pad and even LCD. I did full flash this U600 Board works fine in other U600. But in its own housing and LCD, when power one, everything works, till I slide the phone down and back up, the touchpad do not respond anymore |
03-31-2009, 23:15 | #10 (permalink) | |
Junior Member Join Date: Mar 2009
Member: 1001835 Status: Offline Thanks Meter: 0 | Quote:
04-02-2009, 05:59 | #11 (permalink) |
Junior Member Join Date: Apr 2008 Location: PAKISTAN Age: 38
Member: 752311 Status: Offline Thanks Meter: 2 | I have semilar problem, I did replace flex tape, touch pad and even LCD. I did full flash this U600 Board works fine in other U600. But in its own housing and LCD, when power one, everything works, till I slide the phone down and back up, the touchpad do not respond anymore |
05-14-2009, 17:41 | #13 (permalink) |
Registered User Join Date: Oct 2006 Age: 48
Member: 362673 Status: Offline Thanks Meter: 37 | You must change the lcd and put the adapted one with your phone, this problem appears on U600(B) (black and gold one or grey one ..but not on blue one. You must find an adapted lcd. Post result. Thanks |
The Following User Says Thank You to YOUSSEF1975 For This Useful Post: |
05-22-2009, 15:20 | #14 (permalink) |
Junior Member Join Date: May 2009 Location: North London Age: 38
Member: 1030031 Status: Offline Thanks Meter: 0 | yes,YOUSSEF1975 is right...i have same problems with 3 x U600 in my lab last week,it`s was gold and black U600,you need adapted MB and LCD... cheers |
Samsung E900 touchpad problem T_T | thaoanthony | Samsung Hardware Repair | 4 | 10-28-2010 15:19 |
Samsung U600 Touchpad | TPM | Samsung Hardware Repair | 14 | 12-31-2009 16:54 |
Flashing Samsung U600 and SMS problem | u600owner | Samsung Flashers, Software, Firmware. | 2 | 09-30-2008 10:42 |
Samsung U600 Flex cable problem | deuce22 | Samsung Hardware Repair | 0 | 09-30-2008 01:31 |
Samsung U600 Imei Rebuilding Problem | M.YASIR | UST Pro II | 12 | 07-14-2007 15:24 |
