Eric stay powered up when I hold the "No" button pressed. when I release the button, it turns off. What could be a problem? I checked batt connection, checked keyboard tracks - everything ok. Phone almost new (1 week). Please help! it's common problem on many ericcson phones. |
Hi<br />It seems flash data lost, you have to reflash it!good luck <img src="smile.gif" border="0"> |
I tried to reflash also. when I release the no button, program gives me error "bad response". It's definitaly hardware problem. I thinks some resistor or capasitor or smth like that. please help! |
A transistor is faulty .i'll send you the exact location on 24/8/2001 regards<br />themobileking |
pls be quick, I must return it today. thanks a lot. |
Can I have a copy too ? Thanks in advance. |
I changed four transistors on backside of board with no result. pls help |
ok, thanks all who helped me, especially mobileking. I replaced a transistor with wrong one, it didn't work. THen I replaced with another working one and now phone is working... but can't find a network... What to replace now? PA, filter or something else? <img src="smile.gif" border="0"> ) |
i have same problem with 768<br />Sat can you help me??<br />which trans. is faulti<br />thx |
this transistor has 5 legs and located on opposite side of NO button (component side). good luck! |
