help !!! K850 die !!!! my phone can't power on !!! when I press power on power ic chip verry hot ...and no power on .. I chang power ic ... but still same can you help me thanks |
can you help me... I need |
bro just remove power ic than chk press power b & chk ur pcb is gone heat up or not then post result if pcb i not going to heat up then 100% fault in ur pwr ic if not then chk more shot circut.... Thanks |
reball power ic very care fully..............then flash it |
remove power ic ...I can't power on... |
comfirm u change a new,good 1 power ic ???or u check light coil ???some it will effect power ic hot too..if u change power ic and without programme bck imei the phone oso can use ... |
now phone still can use but no light LCD ...and power ic verry hot...I have chang ic power and light coil but still same |
