how to remove glue under mutimodule on T68 how to remove glue under mutimodule on T68.i try remove same nokia phone but not success.can anyone help |
yes , that what i want , i heared that somebody here can do that , plz help |
You need to by glue remuwer kit (or spray) It made thet glue live in chip, not on board. Olso You can try siply remuving glued modul, but thys way PCB can be destroed... So, look for glue remuver around. I don`t have it yet and don`t no where by it :( Try look aroun forum |
@Porter Thank for reply |
i don't think that glue remover substance could work effectively, i've already tried some of it which comes from china, but none of it could work as it's said .... |
Hi, I dont think that a chimical product exist (for Ericsson or Nokia glue) To remove Components with glue , i use hakko 850 : AIR : 3.5 heater: 3 between 250 ~280 C., first heat side of CCONT or Cobba..., till tin come out . then continue to heat the component and use knife to pull up the compo but very slowly ! almost all glue will stay in component chip, PCB have few glue , then make AIR to 1, heater set to 2.5, then use knife to clean glue in PCB and that all!!!! |
EVILSPEEL everything you say is ok but for nokia phone. did you try to remove glue from T39 T65 or T68?????? just try with this method and ... f**k pcb br |
I tested “knife and air” solution to remove glued CPU on nokia 3210 , worked fine . But only this taken many time and all i need make very carefully. |
all model glue can remove by hotair but sonyericsson (yellow color glue like a stone )is impossibility only to exchange pcb |
CMK&BRKA1 right as along time go i change ccont -flash 8210- mad ( nokia ) without problem exist but in sonyericsson is big different yellow glue is like stone i think no chance to change this maybe in future :D |
ok all now i can take out chip.but my PCB damage :mad: :mad: :mad: |
