Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
09-03-2009, 19:19 | #1 (permalink) |
No Life Poster Join Date: Mar 2009 Location: morocco Age: 47
Member: 1000191 Status: Offline Sonork: 100.1616164 Thanks Meter: 471 | i have a problem with flash for k750i plz hep me v0.915040/UNI CARD SERIAL: 00078143 Loaded 51 flash descriptors CFG:00000000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 Flash ID check:200D Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35437701335008 CERT:RED FLASH CID:49 COLOR:RED Model (from GDFS):K750i MAPP CXC article: R1DB001 prgCXC125952_EU_1_CL MAPP CXC version: R1DB001 Language Package: EMEA_6 CDA article: CDA102338/89 CDA version: R2A Default article: cxc125953 Default version: R1DB001 PROVIDER: 604-01 Network LOCKED USERCODE:0000 RESTORATION FILE NOT PRESENT "R1DB001_CXC125952_EU_1_CL" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 8 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:10100000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35437701335008 CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B Flash ID check:200D Flash props sent ok LDR:070417 1739 NPACXC1327364_COMPACT_SEMC_CS_LOADER__P3T Executing CSCA-based unlock. PLEASE SELECT "USB" AS INTERFACE Elapsed: 14 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:10100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 30 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:10100000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 1 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:10100000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35437701335008 CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B Flash ID check:200D Flash props sent ok LDR:070417 1739 NPACXC1327364_COMPACT_SEMC_CS_LOADER__P3T Executing CSCA-based unlock. Backup security data... loader startup: executed loader GDFS startup: executed loader unlock: executed Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PROCEDURE WAS STOPPED BY USER Can't find attached phone with IMEI 35437701335008 CSCA UNLOCK FAILED Elapsed: 134 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:10100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 3 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:10100000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35437701335008 CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B Flash ID check:200D Flash props sent ok can't get packet start. no ack during gdfs_readvar ! Read locks failed Elapsed: 37 secs. CFG:00000000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35437701335008 CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Starting embedded bootloader... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB Flash ID check:200D Flash props sent ok FOUND VERSION "R1DB001_CXC125952_EU_1_CL" can't open file "C:\BOX\Setool\v0.915040\rest\R1DB001_CXC125952_EU _1_CL" Operator: 000-00 Elapsed: 43 secs. CFG:00000000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35437701335008 CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Starting embedded bootloader... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB Flash ID check:200D Flash props sent ok FOUND VERSION "R1DB001_CXC125952_EU_1_CL" can't open file "C:\BOX\Setool\v0.915040\rest\R1DB001_CXC125952_EU _1_CL" Elapsed: 34 secs. SIGNED MODE (USING SERVER) CFG:10001111100000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35437701335008 CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B Flash ID check:200D Flash props sent ok writing "C:\BIN\SETOUL\k750\R1DB001_125956_TAIWAN_CL.ssw\R 1DB001_125956_TAIWAN_CL.ssw.cry" CURRENT FLASH FILE CID:36 Matching CID according file... SSW uses dynamic hash, dynamic hash len is: 315 HDR block not accepted,error: A9 Elapsed: 14 secs. THAT ACTION IS ILLEGAL,IF YOU DOING IT FOR ANY PURPOSE, OTHER THAN REPAIR PHONE SIGNED MODE (USING SERVER) CFG:10001111100000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35437701335008 CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B Flash ID check:200D Flash props sent ok writing "C:\BIN\SETOUL\k750\R1DB001_125956_TAIWAN_CL.ssw\R 1DB001_125956_TAIWAN_CL.ssw.cry" CURRENT FLASH FILE CID:36 Matching CID according file... SSW uses dynamic hash, dynamic hash len is: 315 HDR block not accepted,error: A9 Elapsed: 12 secs. SIGNED MODE (USING SERVER) CFG:10001111100000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35437701335008 CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B Flash ID check:200D Flash props sent ok writing "C:\BIN\SETOUL\k750\k750i\R1DB001_125952_EU_1_CL.s sw\R1DB001_125952_EU_1_CL.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is: 291 Will flash 291 blocks... SSW loading returns:0 writing "C:\BIN\SETOUL\k750\k750i\R1DB001_EUROPE_5_fs.ssw\ R1DB001_EUROPE_5_fs.ssw.cry" CURRENT FLASH FILE CID:36 Matching CID according file... SSW uses dynamic hash, dynamic hash len is: 153 HDR block not accepted,error: A9 Elapsed: 379 secs. |
09-05-2009, 00:15 | #2 (permalink) |
No Life Poster Join Date: Mar 2005 Location: wales uk
Member: 125632 Status: Offline Thanks Meter: 233 | ur mob is CID49 ur flash is cid36 u not need alternate bypass or signed mode,,,just unlock after flash.plus complete(unless u load a customise in misc) just full flash again,(that main+fs)use cid 49 flash files,in setting,tick unlock after flash,+complete back to se tab then flash db2010 cid 16,29,36,49 normal bypass settings state - all unchecked, there is no any special bypass options for that phones. if "use signed mode" checked - you can only flash signed (flash file CID/DOMAIN=phone CID/DOMAIN) to unlock network locks/repair seczone no settings should be checked. if phone has cid 49 and EROM is damaged - you need use hardware things to repair. to unlock network locks using server "use signed mode" should be checked. usercode can be seen in identify output. |
I have a problem with flash ke770. | joer | FuriousGold | 0 | 02-13-2009 16:40 |
Hello Sir I Have M610 Problem With flashing | abrar9880 | NSPRO | 3 | 08-25-2008 21:28 |
For all who have problem with flashing BB5 phones! | CHEZRACHID | Nokia Base Band 5 ( BB-5 ) | 4 | 03-24-2008 06:59 |
i have some problem with soft for series 60 3rd. Anybody can help me | zicusa | Nokia Multimedia | 0 | 10-17-2006 13:04 |
I have some problem with flashing Sony Z5 | Yar2001 | Sony | 2 | 11-19-2001 15:41 |
