Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 01-12-2016, 14:59   #1 (permalink)
Member: 1511197
Thanks Meter: 17
Arrow xperia m2 d2302 charging problem
need help
Old 01-21-2016, 01:59   #2 (permalink)
Member: 694911
HI.
Same problem here.
Battery tottaly drained and i think i **** the charger circuit.
There is any info schematic how to replace the charger circuit?
Thanks
The Following User Says Thank You to zinom For This Useful Post:
Old 02-07-2016, 22:35   #3 (permalink)
Member: 694911
HI
Just saw a video with very bad quality giving a temporary solution for the battery charging problem because of IC (QFE1101) inside the shield just on the up side of the battery connector failed.
So what you need to do is to add in the pads right after the battery connector on the left side, a diode with the cathode to the upper side and the anode to the lower pad and the phone will charge.
Please be carefull when the battery is very low, because the diode will be very hot because to much current is draining from it. Never let the battery go to a very low voltage so that will not happend.
Hope i help many ppl with this problem.
Regards!
Old 04-22-2016, 13:19   #4 (permalink)
jokkergsm's Avatar
Member: 8866
Thanks Meter: 50
i have one too has fake charging, looking for the charging ic or schematics
btw, QFE1101 is RF PA power management IC
Old 04-23-2016, 09:39   #5 (permalink)
ham_sang's Avatar
Member: 901472
Thanks Meter: 48
I got this sony m2 and few other sony model have fake charging also or very slow charging.Which part is faulty ?
Regards
Old 04-16-2018, 12:17   #6 (permalink)
Member: 1467041
Thanks Meter: 7
Can You help find charging IC ?
Please help
Page generated in 0.13624 seconds with 8 queries
