Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 12-12-2008, 20:25   #1 (permalink)
Member: 238966
Sonork: 1577056
Thanks Meter: 155
W200 Insert SIM Solution (Very Simple)
Hello, I was facing this failure today, so I search over the forum and I find this solution.
But it didn't work for me, so I search the schematics for K510, since for W200 I couldn't find it. And I trace back the circuit to the SIM Connector, removing one more capacitor and a zener diode connecting to the SIM VCC, originally this solution removes one capacitor connected to this contact.
But still no solution at all.
So reading the schematics, I find a resistor between the SIM VCC and the SIM DATA conector, while checking the conection between de resistor and the SIM DATA conector I found there was no conectivity at all, then I realize that giving some pressure to the pin the multimeter beeps, then resolder using a 20x magnifier and finally the solution arrives.
Hope can help somebody
You can see in the attachment the before and after pictures of the connector.
BR.-
The Following 6 Users Say Thank You to pablor1977 For This Useful Post:
Old 12-12-2008, 23:59   #2 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
I had faced the same problem on others SonyEricsson phones like k310,k320,w200...
Reballing simreader pins is the first thing to do when dealing whith a SE phone
The Following User Says Thank You to dragosgsm For This Useful Post:
Old 12-13-2008, 02:14   #3 (permalink)
Member: 238966
Sonork: 1577056
Thanks Meter: 155
Yes that's true!!
But the funny thing here (and this is why I post it), is that sometimes you just heat the pcb and think it's already re-soldered, or in some manner you think that may forget about bad soldering.
Or sometimes also, you just don't start the easy (obvious) way hehe
Thanks, BR.-
The Following User Says Thank You to pablor1977 For This Useful Post:
Old 08-28-2009, 19:14   #4 (permalink)
Member: 527467
BR.-
thanks a lot for this
The Following User Says Thank You to SAURAB For This Useful Post:
k310i,k320,k510i,w200 insert sim solution HERE .::ricky rayya::. Sony Ericsson Hardware Repair 38 09-24-2011 13:29
w200 insert sim gee4234 Sony Ericsson Hardware Repair 0 02-28-2010 21:38
w200 insert sim slpclk Sony Ericsson Hardware Repair 2 12-29-2008 11:43
Page generated in 0.15261 seconds with 10 queries
