Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
09-04-2007, 13:08 | #5 (permalink) |
Freak Poster Join Date: Sep 2005 Location: USA Age: 58
Member: 176971 Status: Offline Thanks Meter: 116 | that's not possible.....this is an integrated circuit which can't be by-passed. Only change it.... BR |
The Following User Says Thank You to edi_vladut For This Useful Post: |
09-05-2007, 10:40 | #6 (permalink) |
Junior Member Join Date: Oct 2004 Location: RO, PH Age: 44
Member: 85549 Status: Offline Thanks Meter: 53 | the easy way is to change DC/DC driver convertor if pcb is damaged by water or...U can use this modify for this u must change LED's connections too, from serial to parallel Use an NPN transistor If are using an FET transistor isn't need to change LED's connection solution is tested/made by me 100% working |
The Following User Says Thank You to baldovica For This Useful Post: |
K300 LCD Lights Problem | anjumm98 | Sony Ericsson Hardware Repair | 9 | 09-24-2010 08:17 |
k700 lcd lihgt | jaleelkuttikkar | Sony Ericsson Hardware Repair | 16 | 06-29-2010 14:57 |
sonyericsson k300 lcd problim | mani0300 | Sony Ericsson Hardware Repair | 0 | 01-01-2010 14:49 |
K300 no backlight on LCD | psych0 | Sony Ericsson Hardware Repair | 11 | 09-02-2008 06:03 |
k300 LCD striped | Djtybee | Sony Ericsson Hardware Repair | 1 | 01-20-2007 17:09 |
