Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
09-06-2009, 09:52 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 774169 Status: Offline Thanks Meter: 123 | k310 /k320 / w200 " STop charging" i have got a lot of SE handsets in which when charger is inserted it starts charging . after 5 mins or so it says " STOP CHARGING " . then again if chager pulled out and inserted it starts chaging . IF any body has tested solution pls post regards [email protected] |
The Following User Says Thank You to mukeshdurg For This Useful Post: |
09-06-2009, 09:59 | #2 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Talk to *** and He Will Listen
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks Meter: 1,104 | the option for that fault 1. clean charging contact inner and outer 2. uem if you can do that 2step i salute you to rtc must better. |
The Following User Says Thank You to venuno For This Useful Post: |
07-31-2010, 15:58 | #7 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 725834 Status: Offline Thanks Meter: 921 | some charging solution,,,,,,,,,,RapidShare: 1-CLICK Web hosting - Easy Filehosting |
K310-k320-k510-w200 Lcd Led Problem | now_mobiles | Sony Ericsson Hardware Repair | 50 | 10-21-2011 10:32 |
W200 K310 K320 Lcd Light Solution | CellWorm | Sony Ericsson Hardware Repair | 10 | 06-16-2011 14:01 |
NOkia 6610 " No Charging" | sonu_nigam | Nokia Hardware & Hardware Repair | 8 | 01-22-2008 04:41 |
1100 & 1108 & 2600 " Not Charging" | adampurhawks | Nokia Hardware & Hardware Repair | 10 | 11-10-2006 15:39 |
