Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
01-22-2008, 13:11 | #1 (permalink) |
Junior Member Join Date: Aug 2006
Member: 338060 Status: Offline Thanks Meter: 0 | k510 short circuit My k510 problem is when the mobile is off, and i connect the power supply to it with 3.9 v , there is 0.13 A current which shows somewhere in the board has short circuit. then my battery deplets very fast. would you please help my which parts i have to check? |
01-25-2008, 09:29 | #4 (permalink) |
Member: 338060 Status: Offline Thanks Meter: 0 | help would you please help me, which part i have to check, i put it in ultrasonic device 10 times and brushed it, all components in mobile such as charger, charge IC, ring IC are OK. mobile works completely but it deplets battery very fast because when the mobile is off there is about 0.13 A current in power supply ampermeter. i will be very happy if some one can help me. |
01-26-2008, 06:10 | #6 (permalink) |
Member: 338060 Status: Offline Thanks Meter: 0 | thanks Thanks dear friend. As mobile can charge the battery and i checked that the battery is charged, Are you sure that by changing this IC the current consumption will remove? thanks is advance |
01-27-2008, 08:44 | #8 (permalink) | |
Freak Poster Join Date: Jun 2005 Location: http://www.paybox.me/r/mourad1 Age: 47
Member: 155016 Status: Offline Thanks Meter: 130 | Quote:
Hopefully that would help u out .. Best.Regards. | |
01-29-2008, 07:09 | #9 (permalink) | |
Member: 338060 Status: Offline Thanks Meter: 0 | Quote:
then i saw your reply and remove the S701 (USB/Serial switch) , wonderful the current consumption disappeared, thanks for your recommendation, then i tried to reflash the mobile to correct the error booting it, but the connection between SETOOLS and Mobile is impossible. would you please help me again what i have to do, how i can reflash the mobile without S701 on the board, i think when i tried to remove the IC one of its PADs on the board was damaged. thank you in advance | |
01-29-2008, 07:21 | #10 (permalink) | |
Once done just Finalize/cutomize ur phone using the appropriate custom pack that matches ur Fs file.. well , let me know if u ever need any further help ! Best.Regards | |
01-29-2008, 09:28 | #11 (permalink) | |
thanks in advance | |
02-04-2008, 05:27 | #12 (permalink) |
Member: 338060 Status: Offline Thanks Meter: 0 | MOURAD120 please help me Dear Mourad120 I replace a new S701 IC but it doesn't work, becuase i think the pads below the IC damaged. so would you please learn me how i can set jumpers instead of the IC, in order to FLASH the mobile by USB port of mobile by SETOOLS. I downloaded the NLSA4717 datasheet (****og switch from intrenet) i think by set jumpers to connect COM1 to NO1 and COM2 to NO2 this may be work or Connect COM1 to NC1 and COM2 to NC2 . Would you please help me, i really need your recommendation. |
c55 short circuit between + and - | Destructor | Siemens Hardware Repair Area | 2 | 05-19-2004 09:41 |
8210 short circuit | Destructor | Nokia Hardware & Hardware Repair | 7 | 01-26-2004 13:53 |
3310 short-circuited with keys - hot and dead | zooboy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-30-2003 14:22 |
3310 short circuit | Shahrukh | Nokia Hardware & Hardware Repair | 2 | 07-13-2003 16:30 |
T28 don`t turn on. Short circuit. Where? | barvik | Sony Ericsson Hardware Repair | 3 | 10-23-2002 10:43 |
