Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
06-21-2007, 23:08 | #1 (permalink) |
Junior Member Join Date: May 2006 Location: Harare, Zimbabwe
Member: 278189 Status: Offline Thanks Meter: 1 | K608i - wont turn on I have a K608i that is not turning on i went to sleep and when i woke up in the morning it was off i thought the battery was flat so i tried to charge it - but i dont get the charging screen - the status light just glows for about 3min then it switches off. The phone will turn-on, i have not dropped the phone can anyone help me The charger is working properly the battery is also working as i tested it on another phone and the phone is able to charge the battery but still will not turn PLEASE HELP |
06-22-2007, 10:11 | #5 (permalink) |
Crazy Poster Join Date: Jul 2005 Location: Between Nirvana & HeLL
Member: 159859 Status: Offline Thanks Meter: 0 | this guide has been around for some time, you can use cracked USB Smart for this: Here is guide how to full repair K600, K608, V600 Usualy with this procedure can be solved ANY software problems (dead, Please Wait, ...) 1. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - Checked - Recover Certificate - NOT Checked - Flash K600_CID49_R2F015_FullRepairFlash.mbn as MAIN file - Connect/disconnect Test Point on phone when software ask 2. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - On Repair tab mark Rebuild SP Area and Remake CRC's - Do Selected Jobs - Connect/disconnect Test Point on phone when software ask 3. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - On Unlock tab mark Clear SP Locks - Do Selected Jobs - Connect/disconnect Test Point on phone when software ask thanks goes to Zulea who made the guide! |
06-22-2007, 12:11 | #6 (permalink) |
Member: 278189 Status: Offline Thanks Meter: 1 | Hi am kinda lost can someone please POST a complete method for each of the solutions you guys mention Can you also please tell me what cables to use Is there anyone that provide me with the software to Use as well Thank you for your responses |
02-23-2008, 21:44 | #8 (permalink) |
Junior Member Join Date: Oct 2007
Member: 611819 Status: Offline Thanks Meter: 0 | Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2000_49_RED OTP CID: 37 Phone IMEI: 35684>>>>>><<<<<<< Flash ID: 890D Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON ERROR: Phone not power up HELP... PLZZZZ!!!! |
02-23-2008, 22:26 | #9 (permalink) |
Member: 611819 Status: Offline Thanks Meter: 0 | GUI v0.91373/UNI standalone version engaged. Card serial:00001283 Loaded 49 flash descriptors ATTACH TESTPOINT NOW, THEN PRESS TESTPOINT OK port recognized as DSS Open COM port OK ChipID:7100,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:115200 err: 45 loader prologue returns invalid status failed to load CERTLOADERS,try to use RECOVERY. Elapsed:3 secs. RECOVERY MODE STARTED port recognized as DSS Open COM port OK err: 45 loader prologue returns invalid status port recognized as DSS Open COM port OK err: 45 loader prologue returns invalid status port recognized as DSS Open COM port OK err: 45 loader prologue returns invalid status port recognized as DSS Open COM port OK RELEASE TESTPOINT NOW, THEN PRESS TESTPOINT OK llbug: trashed answer. All possible recovery loaders fail. That phone not supported Elapsed:13 secs. ATTACH TESTPOINT NOW, THEN PRESS TESTPOINT OK port recognized as DSS Open COM port OK ChipID:7100,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:115200 err: 45 loader prologue returns invalid status failed to load CERTLOADERS,try to use RECOVERY. Elapsed:3 secs. RECOVERY MODE STARTED port recognized as DSS Open COM port OK err: 45 loader prologue returns invalid status port recognized as DSS Open COM port OK err: 45 loader prologue returns invalid status port recognized as DSS Open COM port OK err: 45 loader prologue returns invalid status port recognized as DSS Open COM port OK RELEASE TESTPOINT NOW, THEN PRESS TESTPOINT OK llbug: trashed answer. All possible recovery loaders fail. That phone not supported Elapsed:12 secs. port recognized as DSS Open COM port OK ChipID:7100,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Cowardly refusing to load empty loader. failed to load CERTLOADERS,try to use RECOVERY. Elapsed:0 secs. RECOVERY MODE STARTED port recognized as DSS Open COM port OK err: 45 loader prologue returns invalid status port recognized as DSS Open COM port OK err: 45 loader prologue returns invalid status port recognized as DSS Open COM port OK err: 45 loader prologue returns invalid status port recognized as DSS Open COM port OK llbug: trashed answer. All possible recovery loaders fail. That phone not supported Elapsed:21 secs. |
02-26-2008, 08:55 | #13 (permalink) | |
Member: 610864 Status: Offline Thanks Meter: 2 | Quote:
Chines model wont turn on | nadirghazi | Infinity-Box | 3 | 03-30-2010 17:24 |
dead v360? white screen on bootloader, wont turn on | javalino | Motorola P2k | 1 | 09-08-2007 20:53 |
L6 wont turn on lights on and off , plugged in works fine HELP!! | crunchtime2k | Motorola Hardware Repair | 6 | 09-07-2006 18:57 |
K608i wont switch on after convert to Brown + read code | Weasley | Cruiser Suite | 9 | 09-03-2005 12:57 |
3310 wont turn on | Beef | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-08-2002 10:10 |
