Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
02-12-2009, 19:49 | #1 (permalink) |
Insane Poster Join Date: Sep 2008 Location: Davangere Age: 36
Member: 867466 Status: Offline Sonork: 28008980 Thanks Meter: 37 | G900/g700 Affected Products: G700 and G900 Problem Description: The battery drains a bit faster than usual in standby when the default screensaver is enabled Solution/Workaround: Recommend/instruct users to disable the screensaver (Go to "Main Menu" | "Settings" | "Display" | "Screen saver", select "None" in the drop-down and press "Save") |
The Following User Says Thank You to anilsonysc For This Useful Post: |
07-08-2009, 18:05 | #2 (permalink) |
Junior Member Join Date: May 2005 Age: 46
Member: 146209 Status: Offline Thanks Meter: 1 | Any Soluation for G700 tuch pad I have a pending 7 7nos. handset pending for tuch panel problem if have any soluation so please share with us |
The Following User Says Thank You to hemanshunokia For This Useful Post: |
