Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
06-14-2007, 16:07 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Africa
Member: 180758 Status: Offline Thanks Meter: 13 | k700 i:Lcd/display and light ways I want k700i ligth,lcd and display ways.I have a phone that the two legged ic controlling the joystick is broken off the pcb while trying to repair the lcd light.It cannot be soldered again. Help !!!!!!!!!!!! |
06-15-2007, 18:12 | #3 (permalink) |
Member: 180758 Status: Offline Thanks Meter: 13 | Thank you for sending this post. I mean is there a way to bypass the black component between the joystick and the keypad socket.the component looks like a resistor,placed horizontally but has tiny soldered extensions at both end and most of the lines leading from the joystick diagonally to the keypad socket have a stop there{at the right end} before terminating at the keypad socket. What I mean is that this component has broken off from the pcb,cannot be resoldered hence the joystick is disabled. Help !!!!!!!!!!!!!!!! |
06-18-2007, 11:22 | #5 (permalink) |
Member: 180758 Status: Offline Thanks Meter: 13 | K700i :Still not clear ? We all know how a k700i pcb looks and I said that the black horizontal component with two extended ends between the joystick and the keypad socket pulled off completely from the board.Also damaged are most of the circut lines leading to the keypad socket.Even if I want to replace this component ,there are no solderable points left hence the need for a bypass to correct the malfunctioning joystick. I need full schematics. |
6300 strange display and light problem | gangadhar121212 | Nokia Hardware & Hardware Repair | 5 | 09-04-2009 10:43 |
6630 display ribbon light way | jayanandana | Nokia Hardware & Hardware Repair | 0 | 04-23-2009 19:58 |
KG130 display and light | lucky_gsm | LG Hardware Repair | 1 | 07-07-2008 19:09 |
3230 lcd and light ways need help | markrhi | WD2 & APE (Symbian Phones) | 10 | 06-25-2008 04:28 |
Helllpp!! After Flash V525 With Triplets_g_0b.09.1dr.a I Lost Display And Lights. | KUBAT1 | Motorola P2k | 12 | 10-03-2004 16:30 |
