K700 joy stick K700 when i put keypad joy stick is not working i remove keypad board joy stick is working fine...... what the hell is this.............. action taken: replace joy stick replace keypad board still no lock......... help ..................... thanks.............. |
1 Attachment(s) hello dear check this link trying to jumper and reply me |
write gdfs and flash phone |
@ansari123 :thanks for sol° |
its ok can i more help for u ? |
thanks Quote:
thanks for the help man but still no luck................. |
thanks every body for the help you share.... but still no luck................. |
get a new joystcik fitted, Thank you |
K700i ansari bhai salaam its moin from mauritius i'm working over here as a mobile technician i had got one problem with k700i when i'm swithing it on its just showing light and hangs except the light nothing comes the board is fresh i had tried to flashed it throug my ufs-6 box but i'm not able to do it is there any solution for that or any procedure how can i make it ok please help me out. |
1 Attachment(s) Quote:
thxxx B.R |
salaam ansari bhai i had removed both the capasitors yesterday only but it was having the same problem today i downloaded the allinonemcu flash file for my mt box and i flashd it but while flashing it stopped at 69% was showing error (writing flash problem 0004) but after that when i swithed it on it showed insert sim card. but when i put the sim card it showes insert correct sim card. pls help me with this.***** hafiz |
k700i insert correct sim card salaam ansari bhai i had removed both the capasitors yesterday only but it was having the same problem today i downloaded the allinonemcu flash file for my mt box and i flashd it but while flashing it stopped at 69% was showing error but after that when i swithed it on it showed insert sim card. but when i put the sim card it showes insert correct sim card. pls help me with this.***** hafiz |
