k700i joy stick dear bro i have k700i whos joy stick doesnot work downwords(that is yes button) all right left up and down work fine anybody have schematic or joy stick ways???????? :eek: :rolleyes: :cool: |
i am also having same problem with my k700i, my left joystick doesn't work. help me. |
I'm also having this problem on my 2 k700i I search for solution too. I was said it was software but i tried to flash and it didnt change. |
I had the same problem, and replaced it from T68i and it working now! |
hey dragc, hav u changer ur k700i joystick with t68i. Plzz tell me clearly. Thanks |
1.you can try flashing your phone to release, the joy stick from functioning. 2. you can replace, if you can. try this ...... bestman |
thanks bestman, I think that is hardware problem, I will have to replace my k700i joystick with newer one. Bye. |
First try sw if nt work then ...first thing is clean ur joyestick with CTC liquaid....if again no resultsss then check trackssss and linksss of joye stick...all ok ....at last change it with new good one....u got solution..... |
a very easy solution is to remove the housing and clean off dirt near the joystick and under it. |
can any one give jumper or track for joystick of K700i |
i have also a problem in joy stick k700i all the terminal are gone and remove can any one help me in this problem thanks |
