Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
07-19-2007, 10:58 | #1 (permalink) |
Junior Member Join Date: Dec 2005
Member: 206077 Status: Offline Thanks Meter: 0 | K750i LCD replacement.... fault? Just changed the LCD on a k750i, not a particularly a novice at this, done many but not on this model. Changed the screen and now when i turn it on, it is just showing white. It surely can't be that its fitted wrong because theres only one connected from the screen to the fone. I've never come accross this before.. Any ideas? Cheers |
07-19-2007, 11:31 | #2 (permalink) |
No Life Poster Join Date: Oct 2006 Location: U A E
Member: 364745 Status: Offline Thanks Meter: 719 | pls tel me incoming call and outgoing is good work....if not good reflash the set i hope it will b ok...if incoming and outgoing good work so check lcd conncter... ..::Mr Fone::.. |
07-19-2007, 11:34 | #3 (permalink) |
Member: 206077 Status: Offline Thanks Meter: 0 | k750i The incoming / outgoing is all fine. This is actually my daughters phone. All was working perfect apart from the fact I had to change the LCD. As for checking the connector, there is only one connector from the screen to the phone and this is secured fine, as it should be. |
07-19-2007, 13:05 | #5 (permalink) |
Freak Poster Join Date: May 2006 Location: Almaty, KZ
Member: 274137 Status: Offline Thanks Meter: 8 | there are 2 types of k750 lcd: green and yellow flexes, yellow flex lcds dont work on earlier sw versions like R1AA008, if flex is yellow just flash the phone with R1CA021 |
2630,2600c lcd ways try lcd replace | suntysunty | Nokia Hardware & Hardware Repair | 24 | 11-02-2010 08:06 |
K750i LCD replacement.... fault? | Fonestuff | Sony Ericsson Hardware Repair | 4 | 07-20-2007 16:36 |
T722i LCD Replacement / T720i downgrade? | Rocklobster | Motorola P2k | 9 | 06-13-2004 11:06 |
3210 LCD Replacement | JeoM | Nokia Hardware & Hardware Repair | 1 | 11-15-2001 19:26 |
Nokia 8210 lcd replacement. | jj008 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 08-02-2001 15:45 |
