K750i W800 hung / freeze when memory card is inside 1 Attachment(s) or phone doesn't detect memory card. caution:there is one more reason when you have that symptom:measure pins of card reader(except ground and Vsd pin's) if you have less 1Kohm between pin and ground then you have to change cpu(DBxxxx).this reason is only 5% and the 95% are that shems as i promise time ago: |
Hi, I Have A W810. When I Turn The Torch On After 15 Seconds It Starts To Blink And Does Not Stop Unless I Turn The Torch Off, It Even Happens When I Use The Torch Whilst Taking Pictures. Can Anyone Help |
you are off topic,go to the right thread and don't forget to give explaination what "Torch' is (you can give more words like light,flash light etc. |
thanks sir Great work i will check and come back to you |
...will test it, get often K50/D750/W800 without memory card function. Its realy hard to change the µBGA., so this soltion would be great. THX |
Its work 100%...tested today with D750....GREAT WORK...THANKS!!!!! |
Yes is working, thanks Mr. Platijet !!! WBR golumbu |
thanx i hope to find solustion for hang up in bt =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-==-= [email protected] tc |
thanks it works 100% wbr aksingh |
sorry for my stupidity, but what sort of diode should i use? would the 1N4148 be suitable? thanks in advance |
sorry, what's a double user account? did i accidently submit the application twice ? |
this works!!! you're a genius!!! thankyou very much |
works very well very nice thanks wbr rajiv007 |
hi friends can you show me youre finished product....pls.....pls .....pls...... |
