Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
05-08-2009, 18:32 | #47 (permalink) |
Junior Member Join Date: Dec 2007
Member: 662054 Status: Offline Thanks Meter: 5 | my k800i , same problem, i gave to service engineer and after 4 days he says he is not able to repair it, some main board problem he told. now i want to try this removing 3100 crystal and shorting the pins method. but i have following specific quires before opening my phone. 1. any/what method to use to prevent any ESD damage to phone. 2. How to remove 3100 crystal? its too small, will smd solder tip work. 3. any other major step to follow during the whole procedure, (from people who have done this thing). i also have some problem on camera hardware, as seen in pic, is its just mis placement of some part? or what. can someone tell. Luckily i got K800i disassembly video from http://forum.gsmhosting.com/vbb/arch.../t-499462.html and will follow the same for opening. |
The Following User Says Thank You to kuldeepmob For This Useful Post: |
05-09-2009, 21:11 | #49 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Europe Wienna
Member: 984046 Status: Offline Thanks Meter: 255 | @kuldeepmob 1. ESD shouldn't be of concern, since probability of damage during this is inconciderable small. 2. If you don't have an Hot Air Reflow station (and I presume from your question, that you don't), you shoud use wide solder tip, with lot of solder on it, and warm up element until released. (this can be done, with small non particulary GND-ed components, as tihs one) - clean PCB pads (places where component holds to PCB) with solder wick & large tip afterwards. - do NOT try to mecannicaly remove the component - PCB traces damage possible!!! When finished with removal, proceed with jumpering (sharp/needle soldering tip needed) re. picture: not quite sure what can be cause... I dismantle few of these condition cameras, and each one appears to have this part functional afterall. - Which means that with proper DC & inversing polarity, I was able to open/close camera shutter, wich lead me to conclusion that is malfunction elsewhere. (Didn't have time to look further, tough) BR Haltec |
The Following User Says Thank You to Haltec For This Useful Post: |
05-21-2009, 13:38 | #50 (permalink) |
Member: 662054 Status: Offline Thanks Meter: 5 | @Kruscher and @fanbang 1. can i directly short at "these" (in pic) points Without removing the IC? will that be a correct method. (Coz anyway it will permanently switch the signal path, am i right) 2. detailed pics of camera module are these, i guess i have to open the module to correct it. Could this be a reason for "another application running" message. Please guide . . Last edited by kuldeepmob; 05-21-2009 at 13:48. |
05-22-2009, 07:30 | #53 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 394974 Status: Offline Thanks Meter: 28 | remove n 3100 it have got 8pins hold the pcb as the c/c to the left side short the pins of n3100 as follows first two pins on the right and last two pins on the left it will work sorry i dont have the picture |
05-23-2009, 18:38 | #55 (permalink) |
Member: 662054 Status: Offline Thanks Meter: 5 | How to solder new N3100 @ Haltec Thanks for explaining desoldering of N3100 nicely, And my next query is "how to solder New N3100" using ordinary soldering iron", can i use the same method of heating the whole chip as in desoldering method. |
06-14-2009, 16:20 | #57 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Kuala Lumpur Age: 43
Member: 287805 Status: Offline Thanks Meter: 132 | someone help me regarding camera of k800.. the set not water damage. when capture picture, the pictures was dark... any solutions?? allready tried change the flex, camera module but still same. please help me solve this problem.... |
mr vahid pls update another soft bank,fixed bug and tested,thank vahid.......... | RCB Telecom | UST Pro II | 1 | 07-11-2009 22:47 |
D780JPHF1 is not working ....we need another version to fix phones with arabic | tsarkh | NSPRO | 7 | 05-13-2009 15:54 |
K800 camera error (another aplication runing.....) | pakdirgo | Sony Ericsson | 7 | 11-13-2008 17:51 |
K790 no network after wrong flashing with k800 file how to fix? | fastlink Jogja | Cruiser Suite | 19 | 10-06-2008 17:28 |
another k800 dead | patric | MT-BOX | 2 | 08-14-2007 07:45 |
