Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
07-12-2008, 20:09 | #2 (permalink) |
Crazy Poster Join Date: Dec 2007 Location: I R A N
Member: 662979 Status: Offline Thanks Meter: 7 | do this or read FAQ for db2020. 1. go to empty tab 2. select any db2020 model 3. select cid49 (that is REQUIRED) 4. press recover 5. if board is totally empty (new flash chip), select needed gdfs_in_ssw_format 6. select respective EROM (better use DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw - works for any phone) 7. fill IMEI number, check WRITE OTP (it can be done only once, be careful) 8. press flash phone now normal retail and can be serviced as any other phone. edit: a little example of emptyboard filling for db2020 : count db2020gdfs_in_ssw_format_CID49_BROWN.ssw.cry as empty "template" of GDFS. that template should be written on empty flash chip during emptyboard filling process. then you can write gdfs in .binary format on semc tab, check phone and if all ok - close OTP. Code: so, lets assume we have 1. k810 with empty flash chip 2. db2020gdfs_in_ssw_format_CID49_BROWN.ssw.cry 3. k810gdfs.bin 1. go to empty tab 2. select cid49, press recovery 3. add to fw tab DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw (example), db2020gdfs_in_ssw_form at_CID49_BROWN.ssw.cry, press flash 4. go to semc tab, flash any situable main firmware 5. on semc tab, write k810gdfs.bin using "write gdfs" and misc. edit. 6. back to empty board 7. select cid49, press recovery 8. add to fw tab DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw ,press flash 9. go to semc tab, flash complete firmware (main+fsimage+custpack) OR just flash fsimage,situable to main,written on step4 +custpack 10. now check - phone should be able to turn on normally 11. finally, write IMEI and write OTP, for that 12. go to empty board,select cid49, press recovery 13. add to fw tab k610_erom_cnv_brown2red.cry,fill IMEI, check "write OTP", press flash.important! use only ATTACHED EROMS - they are resistant for EROM UPGRADE feature (means yours phone will stay not damaged after emma/etc) Attached Files |
The Following User Says Thank You to peym@n For This Useful Post: |
6120c mmc not working i chang new ic but same | shani72 | Nokia Hardware & Hardware Repair | 0 | 05-03-2009 06:48 |
K800 after change new flash flashing problem | alan666 | Sony Ericsson | 3 | 12-01-2007 09:25 |
K800/K610 and more new phones flash files in SETOOL SUPPORT | cellularman | Cruiser Suite | 13 | 09-28-2006 09:22 |
can ic flash 2100 changed to ic flash 8250 ? | arif_tual | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 14 | 06-26-2005 14:03 |
