Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
12-12-2008, 14:35 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | k790i error CARD SERIAL: 0000xxxx Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35220701202354 CERT:N/A FLASH CID:52 COLOR:RED setGDFS_params failed failed to setup GDFS Elapsed: 62 secs. i am confuse about cid 51 , cid 52 lp. help |
12-13-2008, 13:49 | #3 (permalink) |
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35220701202354 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok USB CONNECTION REQUIRED. Elapsed: 8 secs. ALTERNATIVE SECURITY BYPASS DISABLED ! ENABLE "SIGNED MODE" ! Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35220701202354 CERT:N/A FLASH CID:52 COLOR:RED phone CID not supported in that mode Elapsed: 3 secs. SIGNED MODE (USING SERVER). Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35220701202354 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing C:\Documents and Settings\omkar\Desktop\R1KG001_FS_AMERICA_2_EV_RED _CID52.ssw CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is:4260 Will flash 213 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed GDFS startup failed (1D) loader GDFS startup failed, that is fatal Elapsed: 244 secs. READ GDFS SIGNED MODE (USING SERVER). Will backup GDFS now. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35220701202354 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed GDFS startup failed (1D) loader GDFS startup failed, that is fatal Elapsed: 16 secs. FLASH OK BUT SHOW GDFS ERROR, NO READ GDFS I TRY WRITE GDFS |
The Following User Says Thank You to omkarvitekar For This Useful Post: |
Need HELP K790i flashing | Error flashing block at address: 0x44140000 | galerinisan | Cruiser Suite | 4 | 06-03-2008 18:06 |
k790i configuration error. .. | harish35200 | Cruiser Suite | 12 | 01-03-2007 06:35 |
configrasyon error after flash k790i | senkron24 | Cruiser Suite | 15 | 10-27-2006 16:56 |
k790i error 002B41 | sankokai | TOTAL MultiServer | 3 | 10-25-2006 21:39 |
