..:: k800 lcd light solution :.. hi mates k800 with no lcd light problem any help ??? i think that must be a jumper solution like " k750 lcd light problem ":) pls share ur knowledge;) thx in adv |
1 Attachment(s) here is the solution of lcd light |
thx dear friend but there is two solution i think 1) change L3103 2)make jumper from left side of C3104 to right upper side of lcd connector which of them is for lcd solution ?????? |
**********:), tnx:):):):):):):):):) |
k800 Quote:
thenks brother nice job.. |
i need w810 back light ic can u help me plz |
Merci................. |
thanksssssssssssssssssssssssssssssssssssssssssssss shav a nice day |
thnx bro........................................, |
thx brow:D ane pake bhs indonesia aja yah:) |
make lcd led connection serries to parallel then remove light ic(6 pin) 1 is ground, 1 is input another 4 pin (same connection) are output and connect (-)volt to ground ,(+)volt to input pin . if input puls ok it work 1000%. it is last solution tri it & injoy. 9same |
Thank's Dear Good working |
Try with diode next to light IC ( 6 pin ) I had luck with that |
