Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
08-28-2008, 12:34 | #1 (permalink) |
Junior Member Join Date: Aug 2008 Location: Sweden Gällivaare
Member: 843510 Status: Offline Thanks Meter: 3 | K800i mic replacement? i'm going to replace the mic on my old k800i..(with hot air gun) how long does one need 2 heat the component/board when mounting the new mic?.. do i read the included chart right..if i heat it around 190-250sec?.. (sounds like along time?) TIA!/H Last edited by harcan; 08-28-2008 at 12:43. |
The Following User Says Thank You to harcan For This Useful Post: |
08-28-2008, 13:03 | #4 (permalink) |
Freak Poster Join Date: Mar 2008 Location: malaysia
Member: 718027 Status: Offline Thanks Meter: 32 | if u r using the same mic as in board.. perhaps ur temp is about 320 pre-heat on the board until those solder r melted...then quickly put the mic at the position...then direct flow it in between 15-20 seconds by inceasing the temp to 345... that is my way...wish it do help u abit... Goodluck to u |
The Following User Says Thank You to spinegy For This Useful Post: |
08-28-2008, 13:37 | #7 (permalink) | |
Member: 843510 Status: Offline Thanks Meter: 3 | Quote:
ok..so 320c until solder melts on the board...and then 15-20sec @ 345c directflow over mic when new in place..is that right? (i also bought some of that high temperature tape to protect components nearby etc..) do you now anything about the chart i posted?....about those time values? regards/H | |
E90, n93, 6600f, ect...Crystal mic replacement for you newbie | Mecaniko | Nokia Hardware & Hardware Repair | 5 | 01-18-2010 13:51 |
6555 mic replacement | kamikaze1a | Nokia Hardware & Hardware Repair | 1 | 01-13-2009 08:37 |
5310 mic replacing | SHAHID99 | Nokia Hardware & Hardware Repair | 0 | 12-03-2008 08:24 |
K800i mic problems. Sw and 2 replacement mics, still no go | dissonant | Sony Ericsson Hardware Repair | 0 | 05-09-2008 03:38 |
Sony Ericsson K800i mic dead | spurms | Sony Ericsson Hardware Repair | 1 | 12-02-2006 01:28 |
