Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 02-28-2013, 15:11   #1 (permalink)
Member: 1567913
Sonork: 100.1617419
Thanks Meter: 6
Question sony ericsson ck13i battery cannot be charged
sony ericsson ck13i battery cannot be charged. you must use a sony ericsson battery
how to solve this problem
Old 02-28-2013, 15:17   #2 (permalink)
sahilfency's Avatar
Member: 1212231
Sonork: 100.1611130
Thanks Meter: 164
first change bettry if not solvad ?
so flesh it if not solvad ?
change charging ic or component
Old 02-28-2013, 15:22   #3 (permalink)
Member: 1567913
Sonork: 100.1617419
Thanks Meter: 6
already flashed
changed battery
pls show me which one is charging ic & component
Old 02-28-2013, 15:22   #4 (permalink)
Cheater -Don't Deal with him-
Member: 1850093
Sonork: 100.1627469
Thanks Meter: 339
just flash this phone using setool then post result tested by me with many models
Old 02-28-2013, 15:24   #5 (permalink)
Member: 1567913
Sonork: 100.1617419
Thanks Meter: 6
i will flash 3 times..............
Old 08-02-2013, 15:36   #6 (permalink)
Member: 550428
Thanks Meter: 25
which 1 is home button to flash with setool
Old 12-09-2013, 14:50   #7 (permalink)
Member: 223818
Thanks Meter: 31
not a soft problem its a hardware problem and if you check the conector battery you will find the midle pin and the gnd are short try to clean the Components behind the battry conector
Old 12-13-2013, 12:36   #8 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 7,629
sony ericsson txt CK13i usb cahrging ways
if not save replace U401
see image below :
Old 09-23-2015, 13:08   #9 (permalink)
DJ Morgan's Avatar
Member: 120827
Thanks Meter: 130
BSI line is broken, make a jumper like in my solution.
BR,
Morgan
Page generated in 0.19875 seconds with 9 queries
