Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 04-01-2010, 22:50   #1 (permalink)
Member: 367027
Thanks Meter: 50
f305 display light issue
can u tell me f305 no light in lcd but light in keypad slution. i try jumer slution posted in forum but no luck . i change lcd flex upper bord flex but no luck .lcd light connection comes direct from power ic i found it from manual.in light coil volts shows near about 5,can any body solve this????
Old 04-01-2010, 22:51   #2 (permalink)
Member: 367027
Thanks Meter: 50
i also chang light coil but no luck
Old 04-02-2010, 21:05   #3 (permalink)
Member: 367027
Thanks Meter: 50
any knowledge about f305
Old 04-03-2010, 21:24   #4 (permalink)
chohansahib's Avatar
Member: 719944
Thanks Meter: 2,117
Hi dear friend,
try this solution ........make jumper and solve ur problem........post result
The Following 8 Users Say Thank You to chohansahib For This Useful Post:
Old 04-13-2010, 10:31   #5 (permalink)
Member: 459869
Thanks Meter: 47
Exclamation
My f305 diode has been damaged. is there any solution? pls advice
The Following 7 Users Say Thank You to alvinteh For This Useful Post:
Old 04-13-2010, 11:05   #6 (permalink)
Member: 816207
Thanks Meter: 37
change in flat fix and cheack in ic light
Old 05-19-2010, 05:23   #7 (permalink)
Member: 91019
Thanks Meter: 62
i tried this and nothing
I still having problem with this phones i tried the jumper and nothing, i changed the diodes and nothing...
Do you have other solution??
Thank You Very Much
Old 05-19-2010, 05:40   #8 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
hv u try reball power ic?????????????
bro try
Old 07-24-2010, 09:38   #9 (permalink)
Member: 726232
Thanks Meter: 3
Thanks sir work for me
Old 08-02-2010, 10:20   #10 (permalink)
janar_jk's Avatar
Member: 154612
Thanks Meter: 824
I have same issu same diode was broken. U can find it from W302.
Old 09-09-2010, 08:11   #11 (permalink)
Member: 434631
Thanks Meter: 77
F305 display light
F305 display light
1st check flex
2nd change good lcd
3rd u can check diode
or some thing related
to hardware before checking
this 2 things dont direct go to
hardware.good luck
The Following User Says Thank You to tlnadar For This Useful Post:
Old 09-14-2010, 07:10   #12 (permalink)
Member: 118395
Thanks Meter: 25
I have a problem too, i have change flex but when switch on every thing ok upto insert sim and set is white screen, change flex again but same problem, set can be switch off. when charging, after charging is display set is white screen, but charging nicely. Any solution. I have also notice that like the above picture that three ics were jumpered.
Old 09-14-2010, 07:29   #13 (permalink)
Member: 385828
Sonork: 100.1612815
Thanks Meter: 73
Originally Posted by chohansahib View Post
Hi dear friend,
just replace these two diodes . tested solution by me.
u can get these diodes from dead boards or in samsung E700 flex cable where these switching diodes are placed near back-light circuit. these are called switching diodes u can't use normal diodes.
Note: use the correct polarity.
Old 08-04-2012, 16:26   #14 (permalink)
Member: 1255883
Thanks Meter: 4
i change the diode it's working for me i take the diode from k750i display backside
SE W395 & F305 Display and Front Keypad no Light libran_s26 Sony Ericsson Hardware Repair 1 11-15-2010 12:29
f305 lcd light faulty softlinkm Sony Ericsson Hardware Repair 20 08-17-2010 05:33
plz halp bro f305 lcd light problem parmodparmod Sony Ericsson Hardware Repair 3 06-08-2010 14:43
Keypad Light Issue on V3 yurais Motorola Hardware Repair 2 06-07-2009 20:07
N73 flickering screen & background light issues sc0ttish Nokia Hardware & Hardware Repair 0 10-02-2006 07:23
Page generated in 0.21099 seconds with 10 queries
