Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 11-12-2002, 23:20   #1 (permalink)
hs_
Member: 16859
T28 No display
Ericsson T28
turn on phone after 2-3 seconds no display
I have changed all parts about display but problem is not solve
Any idea???
Best regarts
Old 11-13-2002, 21:16   #2 (permalink)
Member: 16495
hi
have you try to flash new eeprom?
could be corrupted eeprom.
hope this can help
Old 11-13-2002, 21:49   #3 (permalink)
hs_
Member: 16859
Thx,
I have flashed phone with latest version software...
and eeprom... But they didn't helpm me...
I thing phone has hardware problem...
Old 11-14-2002, 01:33   #4 (permalink)
Member: 10736
hi
just heat up the audio ic or change it .
Old 11-15-2002, 08:42   #5 (permalink)
Member: 17264
you clean LCD Display pad.
Old 11-15-2002, 20:30   #6 (permalink)
Member: 7845
Thanks Meter: 3
change the e2p
then reflash it
Old 11-17-2002, 18:52   #7 (permalink)
Member: 4526
You must try to write eprom from the week of phone production, not with the latest version and than flash it. It worked in my case. You can see the year and week of production on the back of the phone.
Old 11-18-2002, 20:25   #8 (permalink)
kone's Avatar
Member: 17753
Wink
If you have flashed the phone with diferent eeprom types
and display is still not working it must be hardware problem!!
The first idea is that there is broken lead of the first or last contact i cant remember try checking the lead if u have microscope or test it with resistance meter allways it happens near the pad where rubber from lcd is comeing
Old 11-19-2002, 00:14   #9 (permalink)
Member: 13122
T20 work fine but no speaker
heating up the audio ic in most case work 100%
But this one i have same case
Old 11-19-2002, 08:31   #10 (permalink)
Member: 1881
This is 100% hardware problem. You did not have 6 V on LCD power pin. Try to resolder multimode and audio chips, if still no success, put you phone in to the trash can - you have damaged PCB or cpu.
Old 11-19-2002, 22:30   #11 (permalink)
hs_
Member: 16859
Yes you right its %100 hardware problem I have rehot Audio IC and multimode IC but still doenst work
I have measured LCDV its some times ~2,4V some times max ~7.1V When is ~7.1V display is fully black...
May be PCB has be reason...
Its BIGGGGGG problem for me Because it's not my PHONE!!!!!
Thanks...
Best regarts...
notice **** ericsson!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
Old 06-16-2003, 17:21   #12 (permalink)
Member: 26569
it's 100% multi-mode adaptor...
Old 06-16-2003, 23:07   #13 (permalink)
Member: 24581
Thanks Meter: 87
Change 1011120/4CR1A,same IC is for audio,mic and LCD,sometime when audio dont work and You press center of 5,6,8,9 key You hear the sound then try to heat him but not to much.
t28--no display light F C Sony Ericsson Hardware Repair 0 06-11-2002 16:38
Please HELP! T28 no display image after EEprom bin change? Joseph Old Ericsson Phones & Sony Phones 1 06-07-2002 12:11
T28 HELP! No display image after writing new EEprom bin file? Joseph Old Ericsson Phones & Sony Phones 1 06-06-2002 12:25
T28s No Charge, No Network, Dark Displey and no Light Sultan Sony Ericsson Hardware Repair 2 05-15-2002 00:57
T28 no display microera Old Ericsson Phones & Sony Phones 0 05-11-2002 17:14
Page generated in 0.27139 seconds with 9 queries
