Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
02-25-2005, 09:12 | #1 (permalink) |
No Life Poster Join Date: Sep 2001 Location: United Kingdom Age: 48
Member: 6524 Status: Offline Thanks Meter: 246 | P800/900 Lcd Repairing Thanks |
02-26-2005, 21:54 | #2 (permalink) |
Insane Poster Join Date: Jan 2005 Age: 52
Member: 103401 Status: Offline Thanks Meter: 3 | No problem, friend. Touch screen in P900 is glued to metal frame which can be disassembled easy from LCD. First you need to resold the small flatcable from touch screen to main LCD board, then reconnect touch scr. with it's frame from LCD. You need 2 min for this operation. The same operation with P800 needs steady hands and iron nerves because touch scr. in this model is glued directly to LCD. So you need to heat it's surface carefully then disassemble it from LCD using thin and sharp scalpel. Be very careful because touch screen is made of thin brittle glass and can be broken in a moment. Train yourself on the bad LCD's and you'll understand how to do it. BR. |
D 900 LCD light solution | jonymahmud | Samsung Hardware Repair | 0 | 03-17-2009 07:26 |
P800 + P900 LCD touchpad problem.. can they be purchased? | gsmlondon | Sony Ericsson Hardware Repair | 2 | 05-12-2005 18:49 |
6510/8310 lcd repair | sevgigsm | Nokia Hardware & Hardware Repair | 3 | 10-29-2004 02:24 |
C30 only red LCD-repair | Erektus | Trash | 11 | 07-13-2001 14:37 |
